Results 1 to 10 of 11
Thread: Disco 4 - Wiring extras to the battery terminals.
    bobnsue Guest
    I have a disco 4, which has a rear Anderson Plug, Rear mounted Thumper Back-up Battery System, Extra cigarette ports in the cab, twelve pin trailer plug, rear caravan camera. all these are powered through the cranking battery, positive to positive and negative to negative terminals. My car has been slow to turn over and an analysis shows the cranking battery only operating at 78% efficiency. The dealer mechanic advises that this is because all those extras are connected to the negative on the battery. He says they should all be connected to the positive terminal, but that the negative side should be earthed to the body not connected to the negative battery terminal. I am struggling to understand this, can anyone help?
    Your vehicle is equipped with an Intelligent Charging system. The negative lead has a sensor circuit to detect system loads and the charging system reacts appropriately.
    By connecting to the negative terminal you are bypassing this sensor and the system can not understand the loads imposed upon it correctly.
    Same as the days of just jump starting or
    Even just disconnecting the battery are gone!
    You need to RT(F)M Disco 4 -  Wiring extras to the battery terminals. - don't just assume anymore.
    Mar 2016
    Tombie is spot on. There are numerous earth points on the body you can make use of.
    2007 Audi RS4 (B7)
    Mar 2017
    Chiltern
    Could you expand on that please Tombie
    Hey
    so if you earth to the body instead, the negative terminal sensor figures the load?
    I am not challenging this Tomie, I just dont get it.
    I am thinking of adding some power take offs in vehicle and was considering taking it off the positive of the battery but want to clarify if this is in fact kosher
    Nick
    Take power from Positive.
    Connect Negative to the earth points around the vehicle.
    Just the same as a Multimeter can not test current - you need a shunt - the vehicle essentially uses a Smart Shunt to measure current draw..
    Jan 2009
    Hi Tombie,
    What about earthing heavy loads like a winch? Can the various earth points handle several hundred amps?
    Andrew
    D4 MY16 SDV6 HSE e-diff, IID, LLAMS, ARB Summit bar & Intensities & twin compressor, Traxide, GOE sliders & guards,
    TowPro Elite, Mitch Hitch, Rhino platform, Drifta drawers, GME UHF, ProSpeed rear ladder
    Yes they can.
    My winch earths to the post in front of the battery box as per LR install manual.
    Mar 2007
    Kalgoorlie WA
    If you need additional and larger earth posts, Tim (Traxide) offers a stainless steel earth plate / posts which bolt to the OEM earth points on the left inner guard.
    Cheers .........
    BMKAL
    bobnsue Guest
    Smile Thanks
    Thanks Tombie. I understand now. Obviously a few workshops around here need to have a lesson as well.
    Further question though. If I want to put a trickle charger on the battery while it is sitting in the drive for several months, do I connect it to both the battery terminals.
