Thread: Water Pump
    thonger Guest
    Water Pump
    I've got a '78 2 door classic with bog standard 3.5
    It looks like the water pump has started leaking, possibly around the shaft, can I rebuid this or do I have to shell out the $200 odd for a newy?
    disco95 Guest
    My Disco's doing the same thing, I asked the question of the local LR guru here.
    He informed me that it's a replacement job.
    Have a look at the "for sale" section, there's a thread relating to water pumps that may have some useful info for you.
    St Helena,Melbourne
    4.28 MB
    FWD's or Roverdrive are both under $200 for a replacement, mine was $165 a few years ago. I reckon they can be rebuilt using a universal shaft/ bearing but its a pr@ck of a job.
    disco95 Guest
    Supercrap have a powermax water pump for $165.23.
    The model number is W2614 (best to double check this) you'll find it on page 64 of the book hanging near the shelves in store. Providing it's the same edition I was looking at of course. It's under the Rover section, not Land Rover.
    Supercrap don't keep these in stock so they'll have to order one for you.
    Ordered today, it'll be in the store tommorrow.
    thonger Guest
    Cheers fellas, went through my parts books and couldn't find any rebuild kits so figured that was the case.
    Hi cant believe price of part in australia , a pump in uk for your vehicle is between $72 to $128 aud depending on patten or genuine
    Over $300 for the P38A. Ask me how I know.
    Ron
    no
    May 2002
    Heathcote (in "The Shire")
    Re: Water Pump
    Which ever way, don't forget the thread sealant on the long bolts that go through into the water jacket (from memory).
    Bushie
    bump
    I know i'm reviving an old thread here but that's what the search is for isn't it??
    bushie said :Which ever way, don't forget the thread sealant on the long bolts that go through into the water jacket (from memory).
    do you mean your supposed to put the gasket sealant on the bolt threads too, thought just on the mating surfaces, (paper type gasket) ???
