Results 1 to 9 of 9
Thread: D4 leaking sunroof
    May 2017
    Phillip Island
    D4 leaking sunroof
    I have recently bought a 2011 D4 HSE with sunroof and rear glass roof, this car is coloured Fuji White but has blacked out grill and mirrors. When I took it through a car wash that used pressure sprayers I got a surprise when about 2 cups of water came out of the plastic airbag decal/cover on the drivers pillar. Has anybody had the same problem? I'm guessing the sunroof seal must be leaking and am wondering is this something that would get replaced to stop the leak or is it something that is too difficult to be viable, I'll be keeping out of the car wash but haven't driven in any heavy rain yet so don't know if it would leak in that situation.
    Cheers Paul.
    Jul 2016
    Blocked sunroof drain mate. There are tubes attached at each corner which run down the A and B pillars. They get blocked down the bottom the tube fills up and.... you have experienced the result.
    Compressed air usually clears them.
    (I speak from experience.)
    Mar 2015
    Engadine
    Carefull using compressed air, the drain hoses can pop off the gutters then you end up with more water in you cabin. I'm about to replace the drain lines in my D3. If you go back a few weeks I posted links to some LR repair bulletins. Once I get my daughter's 18th birthday party out of the way this weekend I'll start removing trim panels.
    Oztourer
    MY05 TDV6 HSE, Buckingham Blue
    Front Runner Slimline II roofrack and rear ladder, Safari Snorkle, Mitch Hitch, Traxide D3-DU, Bushman Fridge, Icom IC-440N UHF, Hema HN7, Tyredog TPMS, GVIF and reversing camera
    May 2017
    Phillip Island
    D4 leaking sunroof
    Thanks Oztourer and LR Disco I will read the LR bulletin and have a look at the drains over the weekend.
    Cheers Paul.
    Feb 2009
    Does someone have a link to the relevant repair bulletins please? It's either that or I attach a water tank to the passenger A pillar...
    Now 2016 D4 HSE 'Leo' and Steve the Triumph Speed Twin
    Then 2010 D4 3.0 HSE 'James'
    Then 2010 RRS TDV8 'Roger' w traxide DBS, UHF, Cooper Zeons, Superchips remap
    Then 2010 D4 TDV6 'Jumbo' w traxide DBS
    First love 2002 D2 TD5 'Disco Stu'
    Jul 2009
    Mid North Coast, NSW
    51.4 KB
    does anyone know how much water should come through past the seal ? drains are working i just noticed quite a steady stream of droplets getting past in heavy rain, so wondering if it needs new seal or adjustment.
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by LRDisco_Fever View Post
    D2s do that. You'd reckon they'd have figured it out by now.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    350RRC's Avatar
    350RRC is offline ForumSage Silver Subscriber
    Quote Originally Posted by Tins View Post
    D2s do that. You reckon they'd have figured it out by now.
    RRC's do it too, past the windscreen rubber when it gets a bit 'classic'.
    No action required.............. one just waits for the footwells to rust and it just drains out all by itself.
    DL
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by 350RRC View Post
    DL
    That approach works on OKAs as well. Wait, the OKA doesn't have a sunroof. But it leaks from other places. Quite a few it seems.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
