Page 1 of 6 123 ... LastLast
Results 1 to 10 of 52
Thread: Small Mill Machine - Looking To Buy
    Golden Beach, QLD 4551
    Hi All,
    I will tell you a story.
    I need to drill some holes...quite a few. So I thought I would look at getting a cheap Bench Press Drill. Had a look on the internet and local hardware shops and Bunnings. I came across a Boosch mini Bench Press Drill. $400. Nice and small so I could put away after use....limited space in garage. Did a bit of research and found that some are reported as having issues drilling run out. Whilst searching a few mini Mill Machines came up. A little bit more expensive!! Wishing to do a bit of milling on occasions and no longer working, so cannot get it done at work, I though this might be a better option. Now the fun begins when you look at reviews and types etc.
    So, I would like to ask those in the forum who perhaps have one of these type of mills what your thoughts are on the one you have and any recommendations you have.
    I am aware that these cheaper mills will not be as accurate nor do such heavy work but for my needs as a home Mill they would be a good asset.
    I believe many are made at the same Chines factory. Sieg is what I am told. They are also sold here by Ausee pty ltd.
    Many reviews in America recommended certain brands....which are I believe to be a variation on the Sieg..might be wrong and happy to be given that advice/information.
    Cost...well I started off thinking buying a cheap Bench Press Drill...$200-400 and guess now I am up to a bit more.....Not sure at this stage I can justify many thousands. really would like to stay round or below $2000 but if the evidence /advice points to a bit more for future proofing or being frustrated I cannot do jobs required then I guess I would push the boat out a bit more. I am aware in buying on that there is an ongoing cost...reasonably steep at the start for buying equipment needed to make the mill useable...vice, collets, etc. going forward....I also
    Would appreciate your thoughts on a machine that can be adapted to CnC capability further down the track...
    Thank you,
    Chilly
    Jul 2011
    Yarrawonga, Vic
    I bought a cheap chinese Mill Drill from eBay & can not believe how I ever lived without it .
    Ive had it less than a year and it has paid for itself many times over . The only issue I have with it is the motor has a starting issue I can have it replaced under warranty but will upgrade to 3 phase with VFD
    this exact mill / drill from same seller.
    Geared Head Dovetail Milling & Drilling Machine 1100W/240V/ (Mill Drill) | eBay
    The exact same mill goes for up to $5000 when rebranded.
    Jul 2011
    Yarrawonga, Vic
    I use it for fixing Iveco transfer cases
    and machining these things
    Also nothing else can do PCD holes !! - e.g. modify brake rotors .
    I had seen that on Ebay. Could not find any reviews...so it is good to hear from you.
    Interesting how he says a geared head is better than belt...many reviewers say the opposite...any thoughts on that?
    O....and being new to terms used....I just use to use a mill as required and was self taught.....what is BAPPING????
    Looks impressive! I see it is pretty heavy as well as some 340kgs.
    What have you mounted it too?
    Jul 2011
    Yarrawonga, Vic
    I'm self taught too, never used a milling machine until I bought that.
    Geared head is noisy, but more to do with the cheap chinese bearings & casting sand left in from manufacture. I have a tutorial on how to strip it & replace with proper bearings. I'll do that when I change the motor.
    I made a table for it , not bolted to floor, no problem does not vibrate or move.
    Not sure but I think bapping is when you tilt the head & machine at an angle. will upload a photo taken back a bit so you can see better.
    Jul 2011
    Yarrawonga, Vic
    I also put TouchDRO on it , using cheap igaging scales (eBay) and and old Android tablet . look up "Yuryis Toys" for info on TouchDRO it turns the cheap chinese mill into a precision instrument . Love it !!
    Jul 2011
    Yarrawonga, Vic
    heres one showing the 'table' ... er stand . For the price the machine is a bloody bargain. Just don't use tools that are too big for it, like the face mill that comes with it is probably too big if you have the quill extended .
    Ipswich QLD.
    Quote Originally Posted by Chilly View Post
    I think they probably mean tapping.
    Mick.
    1968 SIIa SWB
    1978 SIII Game SWB
    2002 130 Crew Cab HCPU
    Bunbury, WA
    Great thread. Could be very dangerous for my wallet!
    Hey mods, any chance this thread could be moved to "Tool Time" so I have a hope of finding it again in the future?
    Chris
