Results 1 to 10 of 13
Thread: auto box warmup time
    Jan 2016
    Netherlands
    It recently was some 30+c down here and I noticed that it took fairly long for the gearbox to lock up in 4th gear. To give you a bit of context:
    Bloody hot car, hot outside, get in start car and drive of straight away. The climate control had to work hard of course to cool me down, but with that, it surely has heated the radiators behind the condensor extra fast since a condensor can get pretty hot (60c I recon) in no time when cooling the interior. Add to that the outside temp of over 30c and I should think that everything under that hood would surely be hot in the blink of an eye.
    I live in what we call an outdoor area so when I leave my house I hardly ever dip below 60km/h. It's all long straights, no traffic lights nothing but then still it takes the gearbox up to 8km to lock up which I think is fairly long, especially since it seems fuel consumption is way worse in that period
    Is this out of the ordinary?
    -P
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by prelude View Post
    -P
    Can't answer the lock up question, but I can say that 30° C is not hot. That's a mild Spring day here.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Feb 2010
    Townsville, QLD
    Quote Originally Posted by johntins View Post
    I agree wholeheartedly here! It's winter and still getting to 30 degrees
    I do work on an old bloke's P38 here. It's a gems, on coils now sadly, but he also complained that the converter wasn't locking up in top for ages. The transmission fluid level wasn't low, but it also wasn't "full", so I topped it up and took him for a drive. Problem sorted.
    Hope this helps!
    Keithy
    Jan 2016
    Netherlands
    I replaced all the oil back back when I went up north. It is nearly perfectly on the mark, however, I do beleive those ZF units are very picky about the fluid level indeed. iirc the fluid level needs to be measured on idle, in neutral and at a temperature of 20c Tall order to stay within that bandwith when first filling up the system... I'll check the fluid level again and see what's up.
    And ok I get it, 30c is for pussies hahaha. Personally, I feel like rolling over and dying in those temperatures but then we hardly get "normal" heat here. If it get's hot in this otherwise wet country, we get pretty high humidity at the same time so it just feels... eh.
    Thanks,
    -P
    Feb 2013
    Gosford, NSW, Australia
    Thanks,
    -P
    Mate
    The people who live "Up North" in the tropics think that it's freezing down here in a temperate climate, they would have trouble even going outside where you live
    Steve
    Feb 2013
    Tangambalanga
    Hummm,, 30 degs, nice 👍
    As far as "lock up" etc goes, your box should work straight off the mark at any temp. Cold oil verses hot oil won't really make much of a difference to how the box works, other than "perhaps" being a whisker smoother. It's run on pressures not heat.
    I would suggest at this point depending on how long it's been since you've done an oil change, perhaps swapping out the filter and fresh oil. Sounds more like you might have some crud in there slowing up things,, as in jamming valves etc. In a case like this, if your oils dirty, the warmer it gets, it'll work a bit better maybe, or as it gets hotter, it can flow better through various valves and orifice's.
    Avoca Beach
    The TD5 and probably V8 in a D2 will not lock up until the engine temperature has risen. By observation I think this is at about 70C engine temperature . This equates about to when the temp gauge moves to the centre on a D2 TD5.
    AFAIK the 4HP22EH fitted to a 38A will be the same as in a D2.
    If you have a low temperature or faulty thermostat in the 38A this could affect the lock up.
    I am extrapolating here on the assumption that they work similarly. I am sure someone will come and flame me if I am wrong.
    Regards Philip A
    Feb 2010
    Townsville, QLD
    Regards Philip A
    I'm not here to flame!! Promise!!
    Only speaking from experience!
    All P38's that I've driven, both GEMS and Thor, have the converter lock up (under the right throttle position and transmission pressure obviously) at around 60kmh. All 3 of my ones did, plus all of the ones I've worked on.
    Keithy
    Oct 2011
    Fremantle WA
    Quote Originally Posted by Keithy P38 View Post
    Keithy
    Yes, but that is the v8. The TD5 will never lock up in 4th below about 80 kmph on standard tyres etc, and as below, that is not until engine? temp gets to the right point and gives the electronics the all clear.
    Funny how the two are so different in this respect, but I understand it is to do with still getting good torque from the smaller TD5 at lower speeds.
