Results 1 to 4 of 4
Thread: Perentie 6x6 noise from the front when decending into a creek
    Jul 2013
    Scenic Rim
    Whenever my Perentie drives into a drop-off like a creek-bed a metallic groan appears to come from the front driver's side. I have had it checked by a mechanic but nothing was found.
    Any experience with this or next best, any theories?
    Thanks in advance to all that respond.
    1989 110 Perentie GS Cargo 6x6
    ARN 50-721
    Rego 06WDO
    “Liz-Beth”
    Hay Point
    Quote Originally Posted by GMDMD53 View Post
    It could be a few things, Suspension bushes wear, panhard rod, front radius rod, coil spring dislocated or broken, shockie rubbers u/s. Get underneath and check them all out. Process of elimination I am afraid!!!!
    Cheers......Brian
    1985 110 V8 County
    Jul 2013
    Scenic Rim
    Quote Originally Posted by Bearman View Post
    I have looked underneath but can't anything obvious. I would hope my mechanic did the same (but with more knowledge than I).
    I was hoping it was something common and someone could save me some drama.
    I think I will get my wife to drive while I walk close by (risk acknowledged!) and maybe we can pin point it that way.
    ARN 50-721
    Rego 06WDO
    “Liz-Beth”
    Jan 2017
    Geraldton WA
    Those little "Action Cams" are dirt cheap now, Maybe mount one of these under the truck and drive around a bit then replay the footage from the cam to see what the problem is.
    4.6m Quintrex boat
