Results 1 to 10 of 14
Thread: Reliable running gear
    Oct 2011
    So the opportunity has come up where I can build the rangie as a play/touring car.
    Will have a bunch of TJM goodies from work going on (suspension, diff locks & various external mods)
    Currently I run a 3.5 with 350 Holley and 5 speed manual. The engine is pretty tired and worn out now so if I'm going to put some fancy bits on the car I want to make sure the driveline is reliable.
    What are my options?
    Rebuild current 3.5 (options here too?)
    New bottom end
    Replacement long motor
    New chev 350 long motor or similar
    Also while I'm at it, what is it worth to rebuild a manual gearbox and what should I look for?
    I will only be using the car for weekend trips and occasional touring. And obviously showing up the other guys at work in their newer dual cabs.
    At this point I'm hoping to build a decent RRC to maintain my loyalty with them, but if it's too tall an order I will save my pennies and wait a few years to invest in something newer..
    Jeremy
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by jezza89 View Post
    Going to duck for cover here, but who said 350 Chevs were reliable? You want to screw around putting foreign V8s in, in the age group you are talking about, then a Holden 308 or a ford 302 will do you better than the Chev. However, a well built Rover 3.5 would be better than both. It's lighter, the car is designed around it. What's not to like?
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Oct 2011
    Seems Les Richmond automotive go with the LS engines a fair bit: Engine
    Sep 2010
    The Hills.
    152.79 MB
    The LS is a far cry from tHe 350.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    May 2006
    Woolgoolga
    Quote Originally Posted by johntins View Post
    In all aspects!
    Oct 2011
    Ok let's rule out the 350, as it sounds to offer no real benefit over the Rover for the cost.
    The LS are going to be $$$ but if LRA use them a bit then it must be good reason.
    Looking at Rover options again - is it even worth looking at new blocks or is a rebuild the best avenue here?
    Or should i be asking a workshop these questions rather than a forum.
    Oct 2011
    Sunshine Coast
    If you aren't doing engine/gearbox work yourself get some quotes from reputable engine and tranny shops. These might frighten you. To get my LT95 overhauled properly with good reco center diff with parts supplied by forum member who is expert in these was just under 4K. Original quote was 6k. That's just gearbox. Reliable running gear
    May 2006
    Woolgoolga
    All depends on what ypu are chasing.
    Is the 5 speed an lt77? It won't last behind any decent amount of power.
    Also whats the budget?
    My old stroked holden v8 used to use 26L/100km, power was good, but very similar to my 4bd1t i have now which uses 12L/100km.
    For me, i was chasing power, reliability, and economy.
    Oct 2011
    Quote Originally Posted by Vern View Post
    I have the LT77. I have access to a couple other gearboxes though, so if there is a more suitable unit I will see if I can acquire one.
    Budget at this stage for engine work is probably around $5k, though if its worth a few more I might be able to flex it up.
    I'm chasing reasonable power, but nothing crazy, just want it to be strong and reliable. Something that won't mind a beating up the beach now and again, but can also tow a race car on a trailer.
    Quote Originally Posted by Meccles View Post
    I can do 'simple' engine/gbox work myself, as I'm not afraid of pulling engines out and apart to replace components etc - but the furthest I have gone with the rover engine is timing chain, camshaft.
    I've never opened a gearbox before but there is always a first, and I'm willing to learn.
    As far as setting clearances and skimming heads etc, I would probably need to get someone else involved.
    May 2006
    Woolgoolga
    Towing a race car, you want torque! Top hatted 4.6 perhaps
