Results 1 to 10 of 36
Thread: Fault Codes U2023 and P0087
    Apr 2016
    New South Wales
    Hi Gents
    Tonight while driving home I received the above fault codes, lost significant amount of power and the lights "Gearbox error" and "Restricted Performance" illuminated on the dash.
    Ive read the codes as follows:
    U2023 - Gearbox - control module network signal calibration data
    P0087 - Engine Management - Fuel rail/system pressure - too low
    Was hoping for suggestions of things to do/check tomorrow..
    1) Replace fuel filter
    2) Check battery voltage
    3) is there a fuel pump filter? if so, where is it?
    4) anything else I can check myself?
    LRD414's Avatar
    Oct 2014
    Fuel filter, LPFP and HPFP are all possible suspects, in order of cost. The LPFP is in the tank.
    Have a read of this:
    DISCO3.CO.UK - View topic - Robbie's Guide To The Low Pressure Fuel System
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    Jan 2017
    Perth, Western Australia
    HPFP?
    Quote Originally Posted by Lukeis View Post
    Hi Gents
    What was the outcome I have the same errors?
    BradC is online now Super Moderator
    No one of consequence
    Supporter
    Mar 2018
    Perth (near Malaga)
    Quote Originally Posted by orville View Post
    Want to borrow my fuel pressure gauge? I cable-tied it to the windscreen wiper and drove until it faulted. That ruled out the LPFP & Filter, leaving only the HPFP as the potential culprit.
    Jan 2017
    I have a gauge, I bought one to test lpfp. I guess the outcome is obvious, trying to eliminate everything before jumping into a new hpfp.
    Supporter
    Mar 2018
    Perth (near Malaga)
    As mine was all but undriveable last week, I "tickled" the PCV on the HPFP last Saturday which put the fault into remission for about 500k's, but it came back last night. I have a few other things to try, but I know ultimately it's going to need a new pump. I'm just prolonging the inevitable while trying to get a more detailed understanding of the exact failure mechanism.
    Jan 2017
    Thanks for the feedback, I will pass it on to my son. I have trawled the internet for ideas and found nothing. Even looked at Ford and Peugeot motors. Read discussions about the merits of two stroke oil (snake oil?) . I think he is going to take out the lpfp and clean the filter as a possibility.
    Supporter
    Mar 2018
    Perth (near Malaga)
    Which is why I suggested using the gauge. You can actually watch the low-side pressure as the fault occurs. If it doesn't move (like mine) then there would be no point dropping the tank to get the LPFP out and you'd rule out the filter and associated pipework at the same time. Of course if the low-side pressure tanks as the fault occurs then you have more reason to tear into the fuel supply system.
    Jan 2017
    I will try your idea.
    Ean Austral Guest
    Quote Originally Posted by BradC View Post
    Found this part interesting , how did you tickle the PCV on the pump. ??
    Cheers Ean
