Results 1 to 9 of 9
Thread: Puma A/C - fan not working
    Oct 2013
    Richmond, NSW
    Hi guys
    Driving home last night with the A/C on as it was a wet night and we needed to demist due to the superior weather sealing on the Puma, all good
    However today the fan will not work, either in stand alone or with the A/C. The A/C compressor engages when you press the A/C button, the little lamp in the button comes on but no air circulates. I have checked the fuses in the primary and secondary fuses boxes and all seem fine.
    What else might cause this situation?
    Travelrover
    Adventure before Dementia
    2012 Puma 90 - Black
    1999 Td5 110 Ute - White
    1996 Tdi 300 Wagon - White
    Jun 2014
    Dubbo
    Maybe check the plug on the fan motor hasn't come out. If no joy there, check the wires on the back of the fan switch.
    Do you own a multimeter?
    Oct 2013
    Richmond, NSW
    Yup got a multimeter. Not so keen on pulling the dash apart though :-(
    Travelrover
    Jun 2014
    Dubbo
    Maybe you won't have to. The fan motor is in the engine bay, so nice and easy to get at. I'd check there for voltage first.
    Oct 2013
    Richmond, NSW
    Quote Originally Posted by Beery View Post
    Might just have to wait for his torrential rain in the Sydney area to stop long enough to have a look, even my shed is flooded.
    Travelrover
    Oct 2013
    Richmond, NSW
    Had a chance to look at the fan motor today, plug was secure. No time to check anything else as we needed to head out. About 5 mins down the road it started working again. Given this situation I guess it is a loose connection, though the plug into the fan unit was fine. Any other thoughts?
    Travelrover
    Jun 2014
    Dubbo
    Only other likely thing would be the resistor pack on the fan. They're known for packing it in. Its what gives low and medium speeds.
    If the fan still works on high speed then this could be it.
    Oct 2013
    Richmond, NSW
    Thanks Beery
    It's working on all speeds which seems odd!
    Travelrover
    Oct 2013
    Richmond, NSW
    And none were working before...
    Travelrover
