4.0 - poverty pack engine. Least powerful, worst economy (yes even worse than the v8 by a sliver). But, because they are the worst engine, they are usually bought by non enthusiasts (so minimal offroad use) and you can normally get them for quite cheap. Offsets the extra cost of the diesel in terms of economy for a few years.
Not slow by any means, just slower than the V8 and not at all gutsy compared to the diesel. Being a ford engine it's quite reliable and most of the parts are easily replaced/cheap.
I got a 4.0 with 136,000 for 20k. Rear aircon. I overpaid a little but you can get an SE with rear aircon, just has to be spec.
V8 wasn't sold after 2006, meaning you didn't get the 2007 electronic improvements, fixing a lot of the inital glitches the cambus had (brake light sensor for example). You know the car has the upgraded electrics if you have auto up/down windows for the driver and the passenger in the front. It's a jaguar engine, so parts are more expensive.
The TDV6 is pretty much the same one used in the territory, and from what i have read are not as reliable as the other two engines but nothing particularly scary (just normal diesel stuff). I believe it was partially developed by Peugeot or citroen, tinkered with by ford and land rover.
I don't know enough about diesels for servicing and stuff but around the price you are looking, transmission fluid will have to be changed, diff fluids need to be changed (its not on the service guide but it really needs to be done) the suspension compressor will probably neeed to be replaced, control arm bushes will most likely be worn. Wheel bearings might be on their way out too. This is all just from my experience of course. Nothing else really to go wrong that i am aware of. I trawled through the forum before i bought one to learn as much as i can.
If you can push for the D4 the diesels are much improved as i understand it, especially the 3 litre engines. Don't know anything about the V8 but they aren't very common.
Let me know if you have any other questions.
