Results 1 to 10 of 18
Thread: Power from clock
    Feb 2013
    st ives
    Power from clock
    In my 110 I have tapped into my clock wiring to hook up my UHF radio so that I have radio power even when the ignition is switched off .
    I now want to tap into the same source to wire up a spare USB port and similarly have it live when the ignition is turned off so I can charge my iPhone in a convienient location
    Question .....is there any danger of over load .....ie running the clock, the UHF and a USB with my iPhone charging from the same circuit going back to the main battery ?
    May 2014
    Tamworth NSW
    Fuse F29 for the clock is fused at 10A.
    So if the total load exceeds that, you'll blow that fuse.
    Overloading is a possibility.
    -Mitch
    'El Burro' 2012 Defender 90.
    May 2014
    Tamworth NSW
    To further the above...
    Unsure what clock and UHF amp draw is, but the USB would be approx 2A.
    -Mitch
    Feb 2013
    st ives
    Quote Originally Posted by Toxic_Avenger View Post
    Ok that's great .....the UHF radio has an inline 2 amp fuse .....so I guess we can assume that the draw is less than 2 amps .....plus 2.1 amps for the USB port ........which leaves the clock ....so hopefully the 10 amps on the clock circuit fuse should not be exceeded ?
    .......or can you add amps for the 3 things running off that circuit like that ??
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by landoman View Post
    Yes. Total load is a matter of arithmetic. 2+2+2=6. 6<10, so no prob. Question is, why is that fuse 10a? Is there something else on there?
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    May 2014
    Tamworth NSW
    Fuse 29 also supplies the radio.
    -Mitch
    Nov 2014
    Also, from memory only, doesn't it also supply the live 12V in the driver's rear wheel well that people usually pick up for a rear socket to run a fridge?
    Feb 2013
    st ives
    Ok thanks .....so 2 for the USB ,2 for the UHF And say 2 for the clock ......any idea what standard radios run at ...2.....? ..........if so I should be ok on that 10 amp fuse
    May 2014
    Tamworth NSW
    Just suck it and see.
    As long as you have a suitable fuse installed, the worst that can happen is it blows- it's its job after all.
    Turn radio on and up loud (I'd suggest some Metallica for best effect)
    Turn CB on, turn the squelch off so it is making noise (oh, that soothing white noise!)
    Plug in device to charge.
    Collect underpants
    Profit.
    If it goes pop, reassess!
    -Mitch
    Mar 2007
    Great Southern Land
    What is the rating of the clock pos wire ? It may be less than 10amp if F29 powers other things....
    You could compare the clock wire thickness to a known 10amp wire to be sure(ish).
