Results 1 to 10 of 16
Thread: Series Radiator
    Oct 2014
    Northern NSW.Australia
    Series Radiator
    In light of the incorrect hose being sent, on my belief on what I had.
    Any way of telling if your Radiator is, S1, S2,S2A or S3 type.
    Pics would be good.
    Thanks.
    whitehillbilly
    Jul 2015
    Taupo NZ
    20170213_155415.jpgThis is my 1973 SIII....narrower fore to aft than a SII
    Oct 2014
    Are the inlet and outlet of the radiator, the same OD as the motor inlet and outlet, on your 73 S3.
    Whitehillbilly
    Jul 2015
    Taupo NZ
    Yes, both hoses are same diameter both ends.
    Oct 2014
    Ah, Unlike my "S3" then.
    whitehillbilly
    Jul 2015
    Taupo NZ
    Disclaimer....it is a NZ landy, I know the air filters were different between aus/nz SIII's....so maybe the radiators were too?????
    Oct 2014
    Is the bottom inlet of the radiator straight out, 90 to the Radiator, or angled upward.
    Top the same angle as bottom ????
    whitehillbilly
    Jul 2015
    Taupo NZ
    From memory...the bottom outlet of radiator is angled down and to the drivers side. The bottom hose was 'v' shaped, going down from the outlet, doing a 45deg turn and up to the pump.
    Jul 2015
    Taupo NZ
    Top outlet on radiator is straight out, 90deg to radiator. Hose is horizontal toward motor...then 90deg turn downward toward water pump.
    Oct 2014
    Now we need the other Series difference.
    whitehillbilly
