Results 1 to 3 of 3
Thread: Aeon RubberSprings
    Queensland
    Aeon RubberSprings
    I need a set of these but cant find any.
    Timbren in the US make them but I was hoping they were available here.
    One used to be able to get them as I have a set on the rear of the old Forward Control.
    Any ideas on supply?
    Keith
    Queensland
    Well, finally found some. Just ordered a pair but they dont come with the plates.
    https://www.google.com.au/url'sa=t&r...KaeIDON_20-RSQ
    They were an approved accessory by Land Rover back in the day.
    https://www.google.com.au/url'sa=t&r...zwoaTDvf3uEn4g
    Keith
    Hay Point
    I had a set on my series 2a years ago out at Mt Isa Keith. They were standard on Toyota lite stouts I think. Anyhow I adapted it to fit the series. Took the rubber bump stop off and welded a bracket to the chassis which it bolted onto. Then welded another bracket with a locating pin on the axle housing flat spot. Worked a treat when carrying heavy loads. I still have the toyota part number for the rubber bit : 48302-39035
    Cheers......Brian
    1985 110 V8 County
