18th June 2017, 07:17 AM
intermittent wiper setting
Hi all my 2002 discovery doesn't like the intermittent wiper setting if I turn the wiper to this nothing happens although I can hear a click under the dash. If I turn the wipers to the on position they wait a second or two then work and if I then switch back to intermittent wipers they work to. This has been an ongoing issue for sometime any help would be great and much appreciated thanks Phil.
18th June 2017, 09:36 AM
Sounds like you need to clean the contacts on the switch , its a common problem , should take about an hour
19th June 2017, 07:49 AM
Thanks where are the contacts that need cleaning
19th June 2017, 09:28 PM
#4
20th June 2017, 06:20 PM
#5
Thanks discovery I will give it a clean on the week end.
