The attached photos show a fabricated Fwd Outrigger for a LH fuel tank, and I have also attached the drawings as .pdf which were used by the fabricator. No point in someone having to re-invent the wheel.
(Drawing .pdf removed. Need to edit, wee trip twixt cup and lip)
This outrigger is designed for using galvanised tek screws so as not to damage any internal finishes to corrosion that would be left from welding.
A rear hanger is easily manufactured from whatever is appropriate, and available, for adding to the existing outrigger.
