Results 1 to 10 of 11
Thread: EGR blanking
    Mar 2013
    Gymea
    EGR blanking
    Has anyone used this product before?
    EGR Delete - Range Rover Land Rover 3.6 TDV8
    NSW SW Slopes
    Did you see the requirement for an ecu egr delete?
    Mar 2013
    Gymea
    Hey Graeme, yes I figured an ecu delete as well would be required.
    Aug 2015
    WA
    Did you get the kit? If so would appreciate any tips and info on how it went.
    Adelaide - Torrens Park
    I would like to know where they go. The pictures look more like a blanking kit for a 2.7l TDV6.
    Mar 2007
    If you go to their site and try to order them, it won't let you if your outside the UK. They are not listed on Ebay U.K. with all their other kits . I sent a email 10 days ago requesting info, but have had no reply ???
    Laurie
    Mar 2013
    Gymea
    Nah I haven't, I was going to contact BAS about an egr software delete again.
    They still have it as an option on their website.
    DiscoMick Guest
    I assume you are aware that deleting the EGR means the vehicle does not comply with Australian Design Rules and is technically illegal? No-one will probably ever know, but I think it's wise to keep that in mind in case it ever becomes an issue. Just saying...
    Brisbane, Queensland
    A pic of 3.6 tdv8 EGR set up from L322 WSM.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    Mar 2013
    Gymea
    Quote Originally Posted by DiscoMick View Post
    Thanks DiscoMick,
    Yes I removed the EGR on a TD5 defender previously and understand that.
    EGR removal on this would be totally reversible if required.
