Thread: TDV6 head gasket or air pockets in coolant system?
    jwaterhouse Guest
    Hi all, long time lurker but first time poster...
    My 2006 disco 3 TDV6 with 245k kms has been having coolant issues and I'm hoping someone can enlighten me as to the cause.
    First noticed the low coolant warning light on my way home from work, pulled over and found a coolant leak out the top of the expansion tank. Not a lot but enough for a small pool to form under the car, passenger side right under the expansion tank.
    Topped it off and got it home. Have ended up replacing the expansion tank, new genuine coolant cap and water pump in an effort to solve it, however I still get coolant overflow from the expansion tank. I've followed the official LR guide to bleed the system (twice) and the return hose flows strongly back into the tank, coolant looks a little bit airated/bubbly though. Do I just need to bleed it some more?
    I'm concerned it might be a HG issue but have no other symptoms. No white smoke, exhaust smells normal, oil looks normal (no chocolate milk/mayonnaise) and importantly no overheating. Temp gauge always shows normal (about 50%) and no other warning lights. Only concern is maybe its leaking exhaust gases into the coolant system and over pressurising? Haven't been able to do a block test or pressure test yet but its booked in to the mechanic this week so will get them to check. Engine sounds a bit grumbly after a cold start but quietens down after it warms up (couple minutes), related?
    Anyone run into similar issues or have any ideas what it could be? Many thanks in advance!
    Nov 2015
    Black Rock
    Sorry jwaterhouse, but every symptom you've mentioned points to a head gasket or cracked/warped head. The good news is that your mechanic will be able to diagnose it quite quickly as there will be exhaust gasses in the coolant and/or the coolant will be being pressurised above normal. Best of luck with this.
    2013 D4 expedition equipped
    1966 Army workshop trailer
    Sep 2010
    The Hills.
    152.79 MB
    Hope for the best, plan for the worst.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Kingston, Tassie, OZ.
    There is a minor possibility that one of the EGR coolers has failed, excessive pressure in the cooling system is not usually a symptom if that though...😮
    Jul 2012
    Perth- South of the River
    Hi johntins,
    I had similar symptoms. Rough start and idle until warm and gas detected in the coolant. Initially, head gasket or cracked head diagnosis form Rovertech. However, with further investigation (by Rovertech) the gas in coolant turned out to be rusted and leaking EGR valves and rough idle was fixed with three new injectors.
    Gone 05 D3 ARB Front Kaymar Rear Winch E-Diff LRA Tank Dual Battery
    Current 2015 SDV6 SE. Tow Pro Mitch Hitch Llams C/motives 70ltr w/tank 2 x comp Traxide BMS-2 x Aux 150w Solar Uniden Engel ARB drawer F/Runner rack Light bar
    jwaterhouse Guest
    Thanks for the input everyone, really appreciate the insight.
    Dagilmo may be on the money. Just got off the phone with the mechanic who said he's run just about every test he can think of and believes he's narrowed it down to the EGR coolers. Asked him if he thought the head gasket was involved at all and he was adamant it wasn't.
    Two new coolers are on order and should be installed next week. Expensive pieces of kit but I hear it's common they fail so was just a matter of time I guess. Will have to follow up on the injectors too.
    justinc is right, it's hard to find information about EGR cooler faults manifesting as gas in the coolant system, only reference I could find here: http://diesel.org/nozzle/ford-6-0-he...ostic-question
    I've had the EGRs blanked a couple years ago but seems there is no way to bypass the coolers on these engines? Or if that's even a good idea?
    Dec 2011
    Forrestfield WA
    My coolers have been removed and the coolant pipes blanked off. However, the software needs to be changed and an emulator installed to allow for no valves , rather than just blanking them off.
    Bob
