Results 1 to 6 of 6
Thread: Passenger Airbag off warning message
    Fletch Guest
    I have recently purchased a 2012 Discovery SDV6 and am getting the "Passenger Airbag off warning message" coming up in the panel next to the drivers heater temp control. I looked in the manual supplied with the vehicle and it says to turn the switch in the passenger side of the dash panel. My vehicle does not have this switch, a blanking panel is fitted in its place.
    Any advice would be greatly appreciated.
    Mar 2016
    Is it permanently lit, or only when starting the vehicle? It's normal to display at startup, but not normal for it to remain on extended periods. The disable option is only available to European models so it being permanently lit would indicate a fault in my opinion.
    2007 Audi RS4 (B7)
    mikeford Guest
    Don't worry
    My panic when I bought my 2012. ADRs prevent fitment of the switch, ignore it!
    Fletch Guest
    Thanks guys
    Ocean Reef WA
    That was one of my questions for the stealer at first service. Thnx. for the info.
    AlanH.
    Mar 2016
    All warning lights illuminate at startup to tell you that the globe is not blown. They should then all turn off. If you then don't see a familiar warning light at startup you should assume the glove has blown
    2007 Audi RS4 (B7)
