I replaced mine and it was pretty easy. No alarm system in mine though.
How many little holes does it have in the front? If there are are four you can use stiff wire to release the brackets, if there are two (as I found out with mine after using brute force :roll: ) you need a jeweller's screwdriver.
130's rule
