Thread: 3.0 tdv6 egr turn off
    Offroadsport Guest
    Hi all, wanting to turn the egr vales off on my sport. Can this be done with a code reader like the Hawkeye or the i930. Or is it a computer reflash only. Thanks
    Dec 2011
    I think that you will find that it depends on the year of manufacture as it is simple with blanking plates on older ones but needs planking plates plus a software patch on newer ones.
    What year is yours?
    Offroadsport Guest
    Quote Originally Posted by Barryp View Post
    What year is yours?
    Mines a 2010. I didn't believe that there were options for blanking plugs on 3ltrs only the 2.7
    Aug 2015
    WA
    Id like to do this on my 2007 TDV8 3.6 but ive read to many posts so not sure if ineed just the blanking plate kit or if i can just do the software patch so they are closed all the time hence not requiring the blanking plates.
    Has anyone on here done it on this model? If so which way did you go?
    Brisbane, Queensland
    Quote Originally Posted by sandgroper57 View Post
    I've had EGR emulators fitted for the past year. Very happy.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    Aug 2015
    WA
    Did you do the emulators on a 2007 TDV8 3.6 ? I thought they were only available for the later models, where did you get them ?
    Yes. But I think they would work on any 3.6 tdv8. I bought them from Autocode in Perth. Very easy to install.
    This install in a FFRR by 'lazylabs' looks pretty good. I like the way fits in the ECU box.
    fullfatrr.com - View topic - Finally Arrived.... egr emulators....
    Some have had supply/communication problems. Mine arrived ok without any dramas. The alternative is remap by BAS using an IID Tool, or installed by someone else. I think Bluefin will map out the EGR.
    REMLR # 137
    Oct 2011
    Sunshine Coast
    I got my 3.0SDV6 EGR shut off when I got ECU re programmed by Roo Systems in Brisbane. Very pleased with it
    Towcar Guest
    EGR Blanking
    Quote Originally Posted by Meccles View Post
    Hi Meccles,
    What made you choose to blank off the EGR's on the 3.0? i have been reading mixed reviews- with them blanked off does the manifold run hotter than usual?
    Is this easier to do with the 3.0?
    I am at 105,000kms and change my oil every 10,000kms. Might keep this car for a long time too as ive just had transmission flushed.
    Oct 2011
    Sunshine Coast
    The guy that services my car was all in favor of blanking EGRs and I trust him. Certainly exhaust is way cleaner. Re manifold temp I couldn't tell you haven't really looked. We are also keeping car it does everything we need.
