Results 1 to 10 of 18
Thread: Supercharged HSE 4.6
    MAKTRK Guest
    Gidday there all..new to the website and Im hoping I can get some info from the extensive knowledge base here on supercharging a 4.6 P38 Rangie. I will be using the resources of Horsepower Engineering Australia KENNEBELL
    I guess Im after the learnings from people on here who currently own OR have done this to their 4.6 and what problems they encountered. I will be more than happy to post images and progress of the project as it develops but again, any insight to tuning issues/problems will be appreciated!
    Mak
    May 2003
    On The Road
    Welcome to AULRO.COM
    I am looking forward to your Project.
    I know the Gems V8's were supercharged by a company at some stage,,
    I havent read a lot on here about it...
    Bring it on
    Jan 2016
    Netherlands
    Supercharging a P38 V8 basicly means replacing the ECU. That is to say, you would need a new map and thus a chip (two actually) in your GEMS ECU, the bosch thor has not been done yet afaik, or something like a megasquirt which you can piggyback onto the standard ECU. The reason for doing this is that the ECU en BECM just love to talk to each other, in code even and if one of them is not happy with what it is hearing, the engine will not start The reason that this is a problem is because starting the engine in a P38 is not actually a flow of electrons going through the ignition switch to your starter relay but a small signal to the BECM, which in turns sends out an electrical current to power the relay for your starter motor etc etc.
    There has been a bloke in the UK (where else?) that has done a megasquirt on a P38 GEMS, if you want to go that route I can dig it up for you
    AFAIK the supercharged P38's that came from the factory also actually bypassed the ECU. As did the overfinch blokes, they shoehorned a GM V8 in there for more power.
    In any case, great fun to squeeze more power out of those beauties! Mind you though that on a tired engine and driveline this can spell trouble...
    Cheers!
    -P
    May 2013
    A pretty impressive website, but I couldn't find any specific mention of the 4.6 engine. Do they have experience with this engine, and if so have a specific kit for it?
    If they don't, wouldn't there be a few reputable Aussie companys like Harrop etc who may be able to assist?
    Finally, I don't know how much power, or how amenable this engine is to a supercharger, but I reckon it'd need internal upgrades as well, to cope with a supercharger?
    What about an LS3?
    Just a few of my thoughts, but I LOVE V8s (there's no substitute for cubic inches!), any V8, so I'm looking forward to your "journey".
    Good Luck, Pickles.
    Feb 2013
    Gosford, NSW, Australia
    Hi
    This site contains masses of info about the Rover V8, here is a page on forced induction
    Forced Induction and Nitrous
    Small block Chev install
    350 chevy conversion, fitting the engine
    There are also LS1 conversions around
    Good Luck
    Steve
    Feb 2010
    Townsville, QLD
    My opinion, an LS3 and 6 speed auto would be less of a headache than supercharging the 4.6. As mentioned above, you'll get more power and torque plus better fuel consumption from an LS.
    From what I've read in the past, supercharged 4.6's don't get even distribution of air (or something along those lines) and you end up with some cylinders running lean, then bang!! There was one getting around here years ago! Didn't last long at around 7 pounds of boost.
    Keithy
    Jan 2016
    Netherlands
    Keithy is right, there was indeed a problem with that! Mind you, that was a GEMS afaik and the air intake had not been sufficiently modified. The rover V8 can indeed be supercharged without trouble, but you would need to alter quite a few things
    I tried to find the link but can't find it if you have the patience to go through a lot of pages, check the rpi engineering facebook page. I'm pretty sure it was on there at some point
    -P
    Apr 2010
    Lower Hunter Valley NSW
    Supercharge it mate! Just don't plop the blower on top of your bottom section of the inlet manifold - unequal amounts of air going into the cylinders like those have already said. Mount it on the side and have it going to the stock upper intake via the throttle body. Piggy back your existing ECU by using a megasquirt controlling your fuel and spark. Happy days!
    andyaa Guest
    Hi all - my first post here. What brand/make/model supercharger is recommended and who sells them? Mine is a 1998 4.6 with a high spec rebuild and stroked to 5.0l - the people who did the rebuild say 'the engine will easily handle a low boost system' - but what's the first step - who do I approach? Any insights gratefully received. I'm in Melbourne. IMG_1595.jpgIMG_1605.jpg
    andyaa Guest
    Well, I'm not too good at uploading photos - I'm in Melbourne [but in Coventry UK for a couple of months before heading home]. Regards Andrew
