Results 1 to 10 of 12
Thread: slick shift
    Feb 2013
    Queensland
    slick shift
    Hi all has any one installed a slick shift in their d2 manual gear box and if so is it any good as I'm thinking of buying one to tighten the shift pattern up any help would be muck appreciated thanks .
    Phillip
    Dec 2009
    Baldivis WA
    Slick shift as in this Discovery 1 & 2 LT77 & R380 Slickshift (inc TD5) | Online Gearbox Parts Shop ?
    If so, I'd be interested in any feedback as well.
    2014, MY14 Discovery TDV6, Fuji White (2018-Now)
    2003, Discovery 2a, Td5 Manual, Zambezi Silver (2012-2018)
    2007, Adventure Offroad Campers, Grand Tourer (2015-Now)
    May 2003
    On The Road
    so,, slick means no sensation through the syncros?
    or shorter throw?
    Free Again Thanks Dan
    or shorter throw?
    Shorter throw
    Jan 2017
    Thornlie 6108
    Hey lads.
    I don't have first hand experience but watched an install video not long ago. Link pasted below.
    Hope this helps.
    Discovery Slickshift Fitting Video - YouTube
    Feb 2014
    Diamond Creek Victoria
    In the States we had this:
    Apr 2014
    Blair Athol, Adelaide South Aust.
    Quote Originally Posted by Railey View Post
    Snake oil...lol
    Cheers Rod
    May 2010
    brighton, brisbane
    I have the kit and will be fitting it soon. Will get back to you. Basically all it does is replace the bias plate, which is prone to breaking, with a mod that has a solid bit , and stronger springs. Check the link posted earlier from lyhoon 94.
    I’m pretty sure the dinosaurs died out when they stopped gathering food and started having meetings to discuss gathering food
    A bookshop is one of the only pieces of evidence we have that people are still thinking
    May 2010
    brighton, brisbane
    This shows you what needs to be done to get to the bias plate. More or less explains the operation of the bias plate. You will see the how the slick shift overcomes the problem of a broken bias plate if you watch both videos.
    Land Rover Discovery 2 TD5 - Gear Shift Bias Plate Replacement (or how to cure a wobbly knob) - YouTube
    May 2010
    brighton, brisbane
    Quote Originally Posted by kelvo View Post
    That's the one. I'll be forced to get off my backside and install it now, I guess. If I can do it, any one can. Most would be a lot quicker than I, but that's ok. Can't be any harder than the CDL connection kit. Also a good time to clean the top of the gearbox.
