Results 1 to 10 of 19
Thread: Timing on rover V8
    Timing on rover V8
    Hopefully someone has had similar experience to this and let me know what is wrong.
    I have just finished installing the 4.6l into the rangie. It is a fairly new block with the reconditioned heads from my 3.5 and a WW Stromberg carby.
    With my old moter, it ran best when the timing was set with a huge advance (about 22 degrees BTDC) and there was no pinging. I thought it must have been something worn in the motor ie cam.
    I have a new cam in this motor and again it will only run ok when far advanced. The main pulley is ok and the marks are right as I have already checked the TDC mark against the piston on #1.
    My only guess is that there is something wrong with the distributor??? It is really the only comon link between the 2 motors. Both the mechanical & vacuum advance seem to work ok but there must be something badly wrong somewhere. Even though I have it set at 24 degrees I don;t actually believe it can be that high as surley the motor would not run...or at least ping.
    Any ideas?
    Also, is anyone running a 4.6l motor on carby's? I so what carby are you using? I have a feeling the WW is not letting enough air in!
    Forty minutes closer to the hills in a house the bank is kind enough to let me live in
    Sounds like there is something has skipped a tooth somewhere. 22 degrees is about 1/16 of a full rotation. Definitely suss!
    BTW, how are you measuring the advance since you'd be off the scale on the pulley?
    Really just estimating. I measured from 0 to 12 degrees and I was just under double that.
    I was thinking also that it is roughly the degree of 1 tooth but I have no idea what is going on. I think I will take it down to the "ignition shop" and get them to check it and rebuild if necessary. It is running a "Luminition" electronic ignition system so I am wondering if that is stuffed up somewhere.
    Avoca Beach
    Have you actually checked the position of TDC vs the TDC mark on the pulley????
    My first guess would be that is the problem.
    I saw this recently and thought it was a cool idea.
    Stuff some string into no 1 cylinder through the plugol.. I recommend string that will not break.
    Turn the engine to push the piston up against the string. you may have to do it a few time s to compress it and get a consistent reading.
    Then turn the engine backwards until the piston stops in the other direction.
    Hopefully you have marked the first place on the harmonic balancer that it stopped. Mark the second place and midway between is TDC. Voila!!
    I doubt that the engine would run consistently at 50% advance 24+30 as the rotor would probably not be to the contact in the dizzy then.
    regards Philip A
    I did check TDC with a dial guage into #1 cylinder and it matched up perfect with the mark on the pulley.
    Avoca Beach
    IsThe distributor advancing and retarding as you rev the engine?? Have you checked with a timing light by revving to say 3000 and then back to idle?
    I would think any engine would spit back on the starter with that much advance.
    Once it happened to me that the mechanical advance was sticking on a Vdub I had. When I timed it it was Ok then it would advance up but not retard straight away and I would check the timing and it was 20plus. Sure this isn't what happened . Whack some oil down the spindle and check that the advance is moving freely.
    regards Philip A
    SYDNEY -in the shire.....
    <span style="color:blue">i wouldnt go spinning any engine backwards.....
    they dont like it.....it rips ***** out of the timing chain tensioners.....
    did you have the vaccuum advance disconnected when you adjusted the timing....?
    do you know if both the mechanical and the vaccuum advance work....?
    if your dizzy is out by one tooth its simply a matter of remove and refit in the correct
    position....for best performance.....advance the timing out on the raod...
    advance it till it pings then back it off a few degrees......
    they used to always like running advanced....but you will lose a bit of low
    down torque....
    do you do more on road or off road driving.....?</span>
    Wow lots of questions there.
    Phillip - With Vac advance disconnected, it does advance about 1/4 of a pulley when revved and it seems to come back to normal as the motor goes back to idle.
    Yes I had vac advance disconnected when timing.
    Moving the dizzy up or down a tooth does not change the actual degree it is advanced, only the position of the distributor. Which tooth you go in is usually determined by the vac advance mechanism as it limits rotation of the distributor. I have played around with different postitions.
    I did advance it till it pinged, then backed it off about 4 degrees. It is now running ok but according to the pulley it is at 22 degrees BTDC. I could just say "stuff it" and leave it as it is (this is what I did with old motor) but with the new motor and all I would like to work out the problem.
    It is a dedicated offroader, only driven a couple of times a month.
    Avoca Beach
    Well. it all sounds like there is nothing wrong.
    I would drop it back to about 14 BTDC.
    What happens if you do that?
    You will not have much over 4000 anyway with a Stromberg I wouldn't think.
    What about exhaust manifolds? what are you running, the old single outlet ones?
    It may be that the distributor does not have enough total advance or that the springs are too strong and it is coming too late if it doesnt ping with 20plus degrees static. It could also be that the carby is very rich.
    You are really just trading low down torque for revs by advancing so much.
    A good dyno session would be in order to tell you what is happening. I reckon from what you say that you could pick up a LOT of power. A good operator could do timing swings at different revs to plot the best curve.
    Maybe also try a vacuum gauge to see whether you have the cam mistimed.
    There are instructions somewhere on the internet on how to read a gauge. someone on either this forum or teh Range Rover Disco one has posted on this.
    Regards Philip A
