Results 1 to 6 of 6
Thread: TDV8 suspension yellow fault
    Newcastle NSW
    TDV8
    just had turbos replaced so body off, re-tuned to give more power. Only problem is the yellow suspension lean when cornering.
    Using my BB MSV2 there are only three faults in the system suspensionU0434 and Atrive ride module two faults the same C1B07. In the Active ride module of VE there are no faults. The two C1B07 faults are only visible when I scan the whole system on other area. Any ideas of where to find a possible problem.
    I will post the before and after tuning data when I get it
    Taffy
    Current 2008 RRS TDV8
    Current 1995 P38 4.6 HS
    Brisbane, Queensland
    Battery low from sitting for a while? Just guessing.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    Aug 2015
    WA
    Keen to see the tuning data as i want to get mine done also, have you notice any reduction in the lag time ?
    Newcastle NSW
    Before and after tuning data
    Fixed the suspension problem two plugs were reversed.
    Here is the before and after tuning data
    Blue line was car before turbo replacement
    Red line was after new turbos installed
    Yellow line was the result after the tune.
    This was all done an a chassis dyno.
    Wheel readings shown. So crank numbers would be higher.
    It now does not have any turbo lag and it really performs far better than it ever had.
    Consumption around 11 l/100 around town used to get 13 l/100
    mustang2 Guest
    Cost to R&R body
    G'day;
    How much labour did they charge to R&R the body?
    I'm about to have to do mine to replace an engine.
    Cheers.
    May 2003
    On The Road
    Quote Originally Posted by mustang2 View Post
    Cheers.
    anything you want to share Mustang?
