Results 1 to 4 of 4
Thread: Salt corroded aluminium windows
    Sussex Inlet. N.S.W.
    My house down the coast has some salt corroded aluminium window frames. I know I can repaint the frames but how can I kill the salt corrosion deposits?
    Jim VK2MAD
    '17 Isuzu D-Max
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    You could go to BCF or similar and buy a litre of Salt away, it's used to flush outboards of salt.. Mix up the concentration and paint it on the alloy, it might help.
    This Salt-Away spray is ready to use. It is a mild formula that can be used on pretty much anything - steel, iron, stainless steel, aluminium, magnesium, chrome, fibreglass, nylon, vinyl, plastic, gelcoat, glass, leather, rubber and just about anything else you can think of! Designed to strip away all corrosive salt from your tackle and other equipment, its regular use will prevent build-up in your gear, and leaves behind a protective coating to ensure things stay safe and salt-free.
    • Removes all traces of salt
    • "Completely safe on all metals, rubber and plastics"
    Salt Away - 946Ml Concentrate - BCF Australia
    or
    Salt Away - 472Ml Spray - BCF Australia
    Salt Away
    DiscoMick Guest
    Or some rust converter.
    Back down the hill.
    Aluminium polish, it's the aluminium oxide that shines and protects the parent metal.
