Results 1 to 2 of 2
Thread: 25D Distributor
    Oct 2014
    Northern NSW.Australia
    25D Distributor
    After fitting the Su carby and sorted the brakes, ran the Green Machine, down the road.
    It ran quite well, but did appear a bit rough, so back, adjust the SU and back out.
    With it still a bit ordinary, started to look at things.
    I discovered the Vacuum Advance is not working. Checked the S2 dissy and its the same. I can blow and suck air through the hose.
    Wondering if this was normal, pulled the dissy from Gilberts motor, and sucking moved the auto advance.
    Any one have a good one ( advance unit ) or do I just get a new one and fit it. Best place to get one ?
    whitehillbilly
    Oct 2014
    Quick update on the Green Machine.
    Dissy all working as it should. Still appeared to be a miss.
    Re did timing and adjusted SU settings.
    not much different. Then pulling off plug leads, discovered no 3 seems to be a problem. Seemed to run better with plug lead touching plug, not clipped in but arcing. lead change did nothing, as a dissy cap change.
    Yes been down this road with the S11A.
    Then swapped 3 and 4 plugs over, and the problem moved to 4.
    Ended up being a faulty new plug.
    New spare in and spinning the rear wheels in second gear !!!!
    previous problem with new point not working, was solved with running a folded piece of 1200 wet and dry through the contacts twice.
    whitehillbilly
