Results 1 to 2 of 2
Thread: broken bonnet release cable
    Canberra, Australia
    Got quite a surprise yesterday when prior service, thought i'd check under bonnet stuff. Went for the bonnet release lever at drivers feet... bang, the cable snapped. Pulled all the release lever stuff apart and was able to shorten the cable outer, revealing enough inner to get an electrical terminator fitting secured ... with a little help jiggling bonnet, was able to open bonnet.
    I have rigged up a cable exposed just at headlight, so I can open bonnet.
    replacement part ... I am looking for the cable that goes from the release lever, to half way along drivers side of bonnet, and joins with another cable that goes to drivers side catch.
    Prior to calling dealer, thought I'd see if I could find part number on one of the web services/manuals ... no luck so far. Any ideas?
    Michael T
    2011 L322 Range Rover 4.4 TDV8 Vogue
    Aussie '88 RR Tdi300 (+lpg), Auto (RIP ... now body removed after A pillar, chassis extension to 130 & fire tender tray.)
    Mar 2007
    Gen part number should be:
    FPF500050
    Laurie
    2010 TdV8 Autobiography, D2 Td5, RRC 4 Door VM/300Tdi, RRC 2 Door V8
