Page 1 of 5 123 ... LastLast
Results 1 to 10 of 48
Thread: Bouncing when towing
    Hi all
    I have a Jayco Journey on the back of the D4 3.0 SE and as we drive it along it tends to bounce the rear end a bit. We had a hilux before with a smaller van and no issues so have some experience towing but not with air suspension.
    • The van has a measured and confirmed ball weight of 180kgs
    • There is nothing on the rear bumper bar
    • The van is about 2500kgs
    So my questions are
    • Is this normal with the D4 airbag suspension?
    • Would a Mitch Hitch make any difference?
    • Its done 140k so would the rear suspension be tired? And how do you assess this? And what would need replacing please?
    • Is there some sort of set up Im not doing eg particular tyre pressures, etc?
    Its got me perplexed.
    2011 SDV6 3.0L + Torus Kakadu, Winchbar, UHF, roof racks, 1 wife, 4 dogs, not enough fishing rods, and Wallabies supporter.
    May 2009
    Sounds like the symptoms of worn shock absorbers/ dampers,
    The traditional method to test is to remove and push down and check resistance
    Jul 2013
    Perth WA
    I always thought the life of a shock absorber/damper was around the 150km mark so depending on how much towing the vehicle has been doing, it may well be due for some.
    Scott.
    NSW SW Slopes
    There's no rule for normal shock life because it depends on roads travelled, loads, speeds etc but by 140K the shocks are likely way past their useful life especially with 180kg bouncing on the tow-ball.
    Hand operation of a shock cannot possibly be a valid test for worn shocks when normally there's 1.5 tonnes being damped.
    May 2009
    Hand operation will show up a well worn damper, any shocks that ive changed always have a marked difference in feel between old and new . Just my experience
    Sep 2010
    The Hills.
    152.79 MB
    It's not whether you can push them down. It's how they damp it back to stationary that you are testing for. However, there's no way I can do that test on my D2 with King Springs. Pedders do a cheap suspension test. Doesn't mean you have to but their stuff.
    Bouncing is most likely the dampers, regardless of the type of car, but I"d also check you haven't got too much weight on the towball.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Other then OEM, is their a better dampner/shock absorber option? TIA.
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by rambada View Post
    Oh, wow! He knows not what he asks!
    Where's the popcorn?
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    If you do a www search on pitching when towing you will find it has been reported quite a lot. My RRS does it and it has good shocks - you only notice when you haven't towed for a while and by the end of the trip not noticeable as you get used to it.
    Yes can be shocks but I consider it to be an unwanted but not troublesome characteristic of the air suspension.
    Kallangur, Brisbane
    The ball weight of my van is around 250kg & I can honestly say that I have not noticed any unexpected bouncing. Rear tyre pressures are normally around 45psi when towing. Undulations in the road will cause front to back pitching but this is normal to me. My D4 is a fair bit younger than your's though.
    + 2016 D4 TDV6
