Results 1 to 10 of 11
Thread: best vacuum port on a Series 1?
    Jan 2017
    Gentleman,
    I have always been a fan of tuning an engine using a vacuum gauge, but can anyone tell me the best place to take the inlet vacuum pressure from?
    The vacuum advance at the base of the carburettor appears the only spot however this is not always very reliable at the butterfly setup can confuse matters easily.
    The S1 has no brake booster, so no usable port, so what does this august group recommend?
    thanks in advance
    Jeff
    Sep 2006
    Warragul
    vacuum
    Hi
    This has been discussed on the UK series 1 forum. The only thing to do is drill and tap a hole in the inlet manifold.
    Some types of engines seem to respond to the vacuum gauge method of tuning better than others do , don't know why this is so.
    Tuning for me , is rather a hit & miss process on these series 1 engines , I noticed my engine kicking back on start up so I retarded the distributor a few degrees til the kick back stopped , it seems to be running fine !
    If drilling the manifold, from memory the manifold has a water jacket to prevent icing, and you really don't want to drill into this!
    Sep 2006
    Warragul
    drilling
    The water jacket inside the inlet manifold surrounds the carby base, it is nowhere near the two outer inlet ports
    Yes - if drilling a vacuum port, just make sure you know what you are drilling into.
    Jan 2017
    rsz_inlet_manifold.jpg There is a convenient threaded hole already in my Manifold on the firewall side of the inlet and nowhere near the jacketed area ardour the carbs. I assume it is there as a mount for something that my 1953 80" does not have. This seems the most method as I can just drill through the centre, and use the existing thread for a plug and for a vacuum take off.
    Any reasons why not?
    thanks
    Jeff
    I'd be wary about that - I think it is a place for something to bolt on to, and I am not sure a hole drilled into it would go into the manifold itself - that bit on the end could be solid; I can't think of any good reason why it would be hollow!
    Sep 2012
    Westlake ,brisbane
    The bracket for the hand throtle cable bolts to that hole
    Jul 2009
    S.E.Qld
    It's quite save to drill and tap..W.
    Jan 2017
    Quote Originally Posted by B.S.F. View Post
    Many thanks. That is of great help.
    regards and thanks
    Jeff
