Could be an EGR issue - the lack of power etc is a symptom but if there is an EGR problem it will be in the codes and the orange EML will be on. Also if locked open you will get lots of black smoke and reduced power.
I doubt squirting stuff into the inlet side of the engine will have any effect on the EGRs but it might help if you have a MAP sensor issue - possibly blocked - particularly if you have not got blanked EGRs. I would get the MAP cleaned and see how you go.
