Defender Tdi Fuel Gauge easy fix
					I have had a vague reading fuel gauge for a while, and did the usual wiring and earth point checks. I also found a dodgy in line connector on the gauge. All good. That fix lasted about 2 weeks.
So looked like I needed a new sender unit.
Being the cheapskate that I am I decided to take it out and have a look first.
Found that the printed resistance strip to be in good condition, as was the sliding contact blade,
but the clearance of the float pivot pin in the housing (both moulded plastic) was quite large, maybe wear, or wide manufacturing tolerance, allowing the contact to float away from the resistor.
I rolled a strip of thin brass shim around the pin and clicked it back in. Much better, blade stayed in contact however I jiggled the float.
The gauge has always read empty when there was 25l of fuel left, so I also bent the wire float arm down so the float was level with the end of the pickup tube.
Now the gauge is steady and reads empty with 5l of fuel left.
The actual fix was quicker than writing this, the hardest part was getting the bayonet retaining ring back in.
A few s** and b** words seemed to help.
So have a look before you buy a sender.
Terry
				80 109" 2.6 P ex Army GS, saved from the scrappie.
95 300tdi 130 Single cab tray.
2010 Guzzi 750
