Results 1 to 9 of 9
Thread: Puma 2.4 engine crack
    Jul 2010
    PERTH
    Hi
    anyone else had a cracked bore? mine cracked on cylinder 1.
    Safety Bay
    I've seen it on a 1HZ and a Holden 308,the 308 was an old engine,the 1HZ was straight off the showroom floor. Pat
    Yass NSW
    My oldies had it on an XC 302 Cleveland, two head gasket replacements before a crack was found in a cylinder. Surmised that it was a casting fault in the block where the cores had shifted and wear after about 130,000KM weakened the bore enough to crack through the water jacket.
    Tote
    Narre Warren South
    Mate had a similar problem with his Triumph Stag some years back.
    MVC-653F by Colin Radley, on Flickr
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Aug 2011
    Stanwell Park, NSW
    666.1 KB
    Not the bore, but my piston (2.4)
    MLD
    Current: (Diggy) MY10 D130 ute, locked F&R, air suspension and rolling on 35's.
    Current: (but in need of TLC) 200tdi 110 ute & a 300tdi 110 ute.
    Current: (Steed) MY11 Audi RS5 phantom black (the daily driver)
    Gone: (Dorothy) MY99 TD5 D110
    NSW far north coast
    Quote Originally Posted by MLD View Post
    ****, that's almost identical to my Tdi piston.
    I put it down to too high cylinder pressures with the fuel turned up ?
    Nov 2014
    Sydney NSW
    Out of curiosity MLD do u run an EGT gauge or some sort of scan gauge or equivalent?
    Im curious as to your coolant temps amd egt temps under prolonged load.
    Aug 2011
    Stanwell Park, NSW
    666.1 KB
    Quote Originally Posted by 1nando View Post
    Hi Rick - that was on standard tune and no boost increase. A mechanic i spoke to suggested injector staying open too long (over fuelling or misaligned injector timing) but who knows unless you are monitoring the data to see spikes and anomolies.
    Hi 1nando - no EGT sensor but I run a scan gauge to monitor the head temp (on the puma the ecu measures the head temp not coolant temp). Generally i modified by driving style to keep the head temp around 90 dC trying to avoid it climbing to 100 dC. On the time (i believe) that i did the initial damage the head temp flew up over 110 dC in a flash. That was climbing the first long hill around Bell Bird Hill in the Blue Mountains.
    MLD
    Nov 2014
    Sydney NSW
    The 2.2 is different in that the gauge picks up the coolant temp as opposed to the head temp. In saying that i did a lot of experimenting on my set up with coolant temps in relation to egt. Anything over 100 degrees on my coolant temp and my egts are north of 550 degrees on my egt gauge. At 110 I'd hazard a guess that your egts would have been north of 720 degrees.
