200tdi into S2A prop shaft hitting oil return into sump
Has anyone with conversion experience relocated the oil return pipe on the sump? The pipe rubs on the prop shaft gaiter and rips the rubber apart, so I'm looking at cutting the pipe and moving it a couple of inches astern.
i am hoping my welding will be up to the job.
If the pipe is relocated to a slightly higher level will this be an issue? I think the pipe is a basic oil return line and if it's an inch or so higher on the sump wall I don't think it should really matter. Just like to be sure.
Mustlust
1950 Series 1 80in lights behind grill
1950 Series 1 80in rolling chassis looking for a body
1956 Series 1 86in
1956 Series 1 107
1957 Series 1 88in
1967 Mustang coupe 347 stroker
2011 Discovery 4 3.0
2009 110 utility 2.4tdci
