Originally Posted by
alien
Most folk adjust the toe in first and if required adjust the drag rod to straighten the steering wheel when doing it at home with a tape measure.
Not sure if I'm with you there. Unless someone has stuffed with the drag link before, or if it is bent, that should not be necessary. Count the turns lock to lock and halve them (easier, and best done with the pitman arm disconnected ). Steering wheel should be in straight ahead position. Then, hold the wheel ( somehow ) in that position and adjust the toe then.
Or, am I missing something?
JayTee
Nullus Anxietus
Cancer is gender blind.
2000 D2 TD5 Auto: Tins
1994 D1 300TDi Manual: Dave
1980 SIII Petrol Tray: Doris
OKApotamus #74
Nanocom, D2 TD5 only.
