Results 1 to 10 of 12
Thread: TC Effectiveness
    Jun 2013
    TC Effectiveness
    Hi guys, I have just been talking to a couple of mates about a trip to the Vic high country in March next year. I have a pretty much bog standard 95 soft dash, 4.6 is the only mod. EAS works etc. My question is; how effective is the TC, seeing its on the rear. Just curious as my other RRC's didn't have this.
    Thanks,
    Phil.
    Bayswater, Melbourne
    Quote Originally Posted by bikeman View Post
    Thanks,
    Phil.
    No idea personally.. apart from a play in a 93 that had them I think - old school brake pump on the discs; but I have done the trip from Mansfield \ Sheep flat to Dargo right over the high country.
    IMO you will want;
    Diff protectors
    2.5" lift
    265\75\16 tires - I would have had issues having smaller and that was a fair few years ago
    Bullbar with a winch fitted or be with someone that has it just in case
    Duel batteries would also be a good thing for a fridge if you are taking one?
    Jun 2013
    Thanks Chris,
    diff protectors, rated recovery points will be added. There will be a couple of vehicules with winches but in an emergency I have a Tirfor. With working EAS I should be able to raise the car enough when required. Tyres will be near new, 10k, 245 70 16 AT3.
    I was just wondering how effective the Traction Control will be as I have never had a car with TC.
    Phil.
    its hard to explain but dont depend on it
    Do you have ABS in that one?
    Nov 2015
    Black Rock
    Quote Originally Posted by bikeman;2704043[I
    My question is; how effective is the TC, seeing its on the rear.[/I]
    Phil.
    Hi bikeman,
    TC is astonishingly effective. It works particularly well in the type of slippery slopes you get in the Vic high country. It came with my LSE, so I can't comment on how effective it is on a SWB. The TC came as an option with the WABCO ABS.
    I can recall two occasions where it proved it's worth.
    The first was when I had the relatively new car on loan up near Bright. With four blokes in the car I took it for a run on the tracks and plantation where the previous year I had taken my Series 3 LWB with a McNamara rear diff lock and either bar treads or similar. We came to a steep, muddy slope and I remarked that we wouldn't get as far as the Series 3 as we only had the standard road tyres. Boy! Was I wrong. The Rangie simply walked up it with the TC clicking on when needed and we reached the top with no fuss. The EAS was a revelation, too!
    The second occasion was a decade or so later when I was part of a survey team. I had fitted front and rear diff locks but for some reason they weren't working that trip. I had to take a few people along an incredibly slippery river track with some steep sections and to make things worse I had a mysterious misfire under load which seriously limited power. Weather was terrible, too. If it had not been for the TC I doubt I would have made it up some of the hills without winching.
    Mind you, on another survey on a plantation near Narbethong, with earlier generation AT tyres (Hancook from memory) I couldn't get up one wet muddy hill with both diff locks engaged as the tyres simply clogged up with mud! Tried runs with TC only, rear lock only and both locks. Got a bit further with both locks, but not much.
    Your car with rear only TC and EAS and decent AT tyres will easily go anywhere in the Vic high country (unless you go looking for trouble).
    Enjoy your trip.
    2013 D4 expedition equipped
    1966 Army workshop trailer
    Dec 2014
    FNQ
    Quote Originally Posted by RaZz0R View Post
    I wouldn't go looking for the "double black" runs
    Roads?.. Where we're going, we don't need roads...
    MY92 RRC 3.9 Ardennes Green
    MY93 RRC LSE 300tdi/R380/LT230 British Racing Green
    MY99 D2 V8 Kinversand
    Jun 2013
    Thanks for that Diesel, I will be getting everything checked before we go. I have heard some horror stories about the high country. Chris, it does have ABS, which I think works the TC.
    Phil
    Nov 2015
    Black Rock
    Phil
    Yes, the TC is part of the WABCO ABS. It is essential that you change the brake fluid every few years. By that I mean a complete flush. There is a set procedure you must follow.
    But don't worry about the high country. Expect and plan for the worst (snow, blizzard, relentless rain, heatwave, bushfires, breakdowns). The more you prepare and plan, the less disasters you encounter. For forty or so years I have travelled the high country nearly always with just the one vehicle. I've had a broken axle, eight hours winching (downhill in the snow!), a broken rear diff (but on that occasion I was with another vehicle), days of heavy rain, flooded rivers, bushfires on an opposite ridge and goodness knows what else. But I was prepared for all of that (well, not the bushfire) and most of the time most trips have been uneventful. Just remember that the best way to get a Landrover from A to B is to go as slowly as possible. They will walk up mountains in first low (just leave it in Drive, low range) with the engine revs just on peak torque (not screaming and flat out as you see some buffoons do). Your Rangie will walk over the rockiest tracks nice and gently if you go slow enough for the EAS to do it's thing. Yes, there are the odd occasions when deep soft sand or mud will require a bit of momentum or a steep slippery slope will require a bit of speed, but a spinning wheel is a wheel without traction, so try to keep that to a minimum.
    If this is your first trip, try to go with another vehicle and share the recovery gear and spares etc.
    Quote Originally Posted by DieselLSE View Post
    That is great advise right there!
    Also be aware that with the ABS when you walk it down steps she will wanna roll and drop down them because the ABS picks up skipping.
    I ripped the ABS out and put a Disco booster in place of the ABS pump with a reducer for the rear lines. Wasn't that hard at all and gave really good control for getting down steps on the brakes where you have no engine braking.
    But thats another story
    May 2003
    On The Road
    Not trying to confuse the issue,, or go offtrack
    The RR's pioneered traction control,, first rears then all 4,, then the D2's got it,, but by then the RR's had far Superior TC software (and still have )
    My question is,, with TC, the trick on the 4 wheel TC on D2's is to either rev the tits off it and wait , or stop a wheel,,
    but if that RR only has it on the rear,, how to activate???
