The LT77 was originally a Jaguar Gearbox.
Wisdom prevailed and the R380 was the replacement.
If the LT77 is knackered then consider replacement with the R380.
http://users.lia.net/landrover/gearboxes.htm
my 94 200tdi with 350000kms on the clock has developed a bearing noise in the transmission somewere.are all lt77 boxes the same e.g.
triumph etc
Mahn England
Ex 300Tdi Disco:
yep thanks will the r380 fit the 200tdi motor
An R380 can be made a straight swap for an LT77s in a 200tdi disco, but not in a 200tdi Defender.
Paul![]()
When did they change from LT77 to the R380?
in diesel terms when the engines changed from the 200TDi to 300TDi.Originally posted by timberwolf_302
In Disco terms - they were introduced with the release of the D1 update in May 1994 (build from Jan 94)
Gazzz
Why no fit defender Boss?????Originally posted by Defender200Tdi
Paul![]()
what about drive shafts are they the same
