Results 1 to 10 of 14
Thread: Soldering iron
    Jan 2013
    Molesworth,Tasmania
    Soldering iron
    Struggled to get a couple of brushes soldered in on a starter motor i was cleaning up today. Not sure what my current one is rated at - but was wondering - go for a gas option or the highest watts i can find. Not needing it to be portable, just stronger.
    All comments gratefully received as usual,
    cheers,
    D
    1957 88 Petrol (Chumlee)
    1960 88 Petrol (Darwin)
    1975 88 Diesel (Mutley)
    Moruya Heads/Sth. Coast, NSW
    Quote Originally Posted by Dark61 View Post
    cheers,
    D
    Small tip soldering irons don't hold the heat long enough so you need to get one that has enough power to keep the tip hot, and consider that you may need a flux or at least a good cleaning, I have never had real good results with rosin core solder, Regards Frank.
    I still have a 150 watt 12 volt Scope iron and it's in my Rangie's tool kit.
    Dad used to use the 3.3 volt version in the Fifties.
    The 12 volt version is identical except for a looong lead and is still available. SCOPE 107-HI/BL SOLDERING IRON 12V 30-150W SUPERSCOPE BLACK HANDLE | Auto Cable & Accessories
    It can get red hot at the copper tip if one holds the switch down for too long.
    (My usual iron is a Weller temperature controlled iron I bought for $27 in 1971.)
    Homestar's Avatar
    Aug 2010
    Sunbury, VIC
    Yep, I'll second the scope - I built one as a 1st year apprentice and it's still going strong. I also have a temp controlled iron, a gas powered one which is handy fit small jobs on the car, etc and 3 or 4 other irons of various sizes ranging from the sublime to the ridiculous.
    Dec 2014
    FNQ
    I'll make it 3 in a row.
    The 3.3v version of the 180w Super Scope (SS) iron that Ron linked you to still has every single part available for it as a replacement part.
    I've still got one which I bought in 1987. I've used 4 carbon tips, one stainless barrel, and about a dozen chisel points in that time. Also have the orange handle version, which is 100w.
    It's worth buying a spare set of chisel point tips for it, and a set of carbon contactors. then you're good to go for at least 20 years. I'm not a fan of the conical point, the iron's too hot for them. They have a smaller newer iron for that style tip.
    a block of sal-ammoniac is handy also. (tip cleaner for heavy duty irons - stinks like nobodys...)
    The transformer has changed on the scope irons - it's now in an orange case, instead of being the bare transformer with the iron rest on the top and bakelite covers on each side. I think it's 3.3v and approx 30A
    For the really really huge jobs like soldering lugs on 0000 B&S you can't beat a pot of solder or a plumbers soldering iron - aka the sievert blowtorch with the huge copper chisel point slug out front.
    Roads?.. Where we're going, we don't need roads...
    MY92 RRC 3.9 Ardennes Green
    MY93 RRC LSE 300tdi/R380/LT230 British Racing Green
    MY99 D2 V8 Kinversand
    I forgot about the Primus propane torch with a large copper tip for soldering. I must have had it for 30 years - I got it from my father.
    Similar to this:
    JDNSW's Avatar
    JDNSW is online now RoverLord Silver Subscriber
    In 1964 I soldered up the leak in the top radiator tank of my Series 2 using a Scope soldering iron. Still got it somewhere.
    Jan 2013
    Molesworth,Tasmania
    Scope it is then Gents.
    D
    Crikey, they aren't cheap any more! I wonder if you'd find a secondhand one on eBay or Gumtree?
    Jan 2013
    Molesworth,Tasmania
    Yes I thought ouch! But you get what you pay for. Will have a look at gumtree etc.
    cheers,
    D
