Thread: D3 Roof Rails
    Thedogsbollocks Guest
    D3 Roof Rails
    All sorts removed plastic plugs to reviel screww holes
    Dec 2011
    Adelaide
    142.79 MB
    My Disco3 is 20km away, so going from memory here.
    You should have 2 long strips of alloy covering up the rails, with 4 or 5 plastic plugs in those strips.
    The plastic plugs push into threaded mounts in the roof - if you lever them up, they pull out - or they may need some help to get them out by unscrewing them from the holes.
    If you pull all the plugs out, you can lift out the alloy rail covers (and clean the crap out under them!).
    I fitted Rhino rack rails to my D3, and it was quite painless once the plugs came out.
    More info here, and photos of mine in post 25
    Roof Bars - D3
    2012 L320 Range Rover Sport Fuji White
    REMLR 012
    No 5 Trailer ARN 177-295
    2006 Disco 3, 4L V6 Petrol SE Deceased Feb 26 2023
    SOLD Engineers Trailer - no id
    SOLD RAAF 231194 Perentie 110 GS - SIR ANGUS
    SOLD 4MP COY Series 3 FFR 30-209
    Jan 2015
    These instructions might help - it is as described by Jeepster above...
    Land Rover Discovery 3 & 4 Roof Rail Installation Instructions 161744.pdf
    Everything is easy when someone else is doing it
    MY14 SDV6 SE Corris Grey
    Compomotive 18s : D697s : Traxide DBS : LLAMS : ARB compressor : IC-455
    Rhino Platform : GOE compressor, Tx & front bash plates, deluxe sliders
    May 2015
    Powerful UK have lots of useful videos relating to adding/installing items to Land rovers. This link is for the video relating to roof rails which may be of use to you. I certainly watched it a few times when fitting my short rails. I agree with Aussie Jeepsters' above comment about spinning the plastic plugs out of the original roof channel strips, it made getting them out easier. The plastic/rubber layer covering these channel covers was easily damaged, so I took care when levering these christmas tree plugs out as I may want to replace the channel covers one day.
    Land Rover Discovery 3 & 4 Roof Rails - Extended - Silver
    Mar 2016
    And always recut the threads with a tap as they are inevitably gummed up with sealer or something. You'll need to be able to get the bolts/screws to engage fully.
    2007 Audi RS4 (B7)
