Results 1 to 10 of 20
Thread: Cheap engine rebuild
    Jul 2011
    burpengary
    Hi guys, I know this is an old question but money is tight and I don't need a motor that will last another 20+ years. I'm planning to clean and straighten block obviously but if crank and bores are ok just want to do stock rings and bearings if not then will do.Hoping hone will do bores. I have near new rego heads to go on so need timing chain/ gears, oil pump, water pump bolts and gaskets to put all together. Can anyone recommend someone in Brisbane to talk to who won't take offence that I don't want top hat liners or want to spend less than two grand on a four grand car. Any info would be awesome.
    May 2003
    On The Road
    so, second hand stuff is ok?
    I wouldnt be surprised if there isnt some second hand stuff squirreled away by some here,,
    Jul 2011
    burpengary
    Well, block not ok, bores are all 7 thou out of round, needs bore,crank needs machine, heads and block need skimmed. Lovely. Oh well, all bits available at rimmed bros in UK, so much for cheap. $2000 so far, with no assemble. Will see how much it goes and keep posted for info sake.Cheap engine rebuild Cheap engine rebuild Cheap engine rebuild
    Feb 2010
    Townsville, QLD
    Rebuilds are never cheap! Good luck mate!
    Quote Originally Posted by Keithy P38 View Post
    Yes - I totally agree - there is never a cheap rebuild. I have just rebuilt a RV8 - doing the build myself and contracting out the tech bits like crank and honing - the dollars rapidly build up.
    Timing cover/oil pump - see the Markets
    Jul 2011
    burpengary
    OK, update time. Complete rebuild kit less head bits as my heads are good, from rimmer bros in UK, delivered, $1200 and change. This includes them swapping out standard pistons and rings for +20 set. Includes Cam and Cam kit, oil pump, head Bolt's etc. Engine guys pressure tested block and say block is good to go. $800 to a grand worth o f machining and cleaning...depending on cash I can assemble or they can. Light at end of tunnel?... we'll see.
    Quote Originally Posted by deano2469 View Post
    I hope so.
    See Land Rover V8 Cylinder Leak / Crack - YouTube
    Revised Land Rover Engine Block Tester - YouTube
    Rover V8 Block Cracked (Trailer) - YouTube
    Jul 2011
    burpengary
    Yeah I saw similar videos and that's why I asked them to make sure...I can only hope I guess, gotta trust em for now...cheers.
    What engine is it - 4.0 or 4.6 and low comp or hi comp?
    If you are getting the block bored out to fit +20 pistons I would get the block pressure tested again afterwards as it has been known that on occasion the boring process can move the liners.
    Did you get new lifters to go with the new crank?
    Ron that crank and conrods you gave me those years back are now in a sort of running engine - crank needed a 10 though grind. I used 4.0 pistons to get a bit more compression.
