Results 1 to 4 of 4
Thread: 94 110 300tdi rear tailshaft uni part number
    Hay Point
    Anyone know the part number ( not the landrover part number) for the uni joints on a 94 300tdi rear tailshaft. I think they are the 75mm ones. I know they are not the same as the 82mm ones on the county and perentie which are K5-13XR.
    Cheers......Brian
    1985 110 V8 County
    Aug 2012
    Logan,Queensland
    Size is 75mm x 27 cup.
    '95 Defender 130 Single Cab
    HS2.8 TGV Powered
    98% of all Land Rovers built are still on the road.
    The other 2% made it home.
    Cost difference between Britpart and Genuine seals: £2.04. Knowing that your brakes won't fail at any moment: Priceless.
    Kingston, Tassie, OZ.
    Tvc100010.
    75mm cross 27mm cup.
    Jc
    NSW far north coast
    Use the part number JC has quoted.
    There are two versions of that size uni, the standard Spicer 1300 and the Rover part quoted above.
    The GKN/Rover version (and Hardy Spicer can supply them too, can't recall of the top of my head what their part# is) uses a larger trunion to match the strength of the physically larger 1310 Spicer uni.
