Results 1 to 10 of 13
Thread: Domestic solar panels for a vehicle
    Bracken Ridge, Qld
    A mate came around yesterday and showed me his Hilux rig. He has a couple of big domestic solar panels mounted on racks above his tray (he had teh panels which came off his roof when he got a new system)
    I can't recall the specifics of his set up, but he says it is cheaper, for more power output than a normal solar 12V system sold for vehicle use. (I'm not convinced. It MAY be the case if you already have the panels perhaps but if having to purchase panels I doubt it's better?)
    He runs his two panels through a Victron 75/15 mppt (means nothing to me but might help others when offering opinions on the matter) (manufacturer info link BlueSolar MPPT 75/10, 75/15 & 100/15 (12 / 24 Volt + load output) - Victron Energy )
    One thing I did find impressive is that he has fitted a bluetooth dongle to the Victon and with an app on his phone can see the last 30days of consumption and production, plus the amount of time at each level of charging
    Edit: Oh I better add that he claimed one main advantage of this system is that vehicle panels require direct sunlight whereas domestic panels can charge even on cloudy days. Any truth in this?
    So I suppose I'm wondering whether its worth pursuing any such system or whether a 'normal' 12 V system with 200W panel would be a better way of going?
    How would costs compare?
    I assume the usual vehicle panels would be smaller/lighter than domestic panels.... ?
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    Bracken Ridge, Qld
    My mate has [privded more info on hi set up:
    Victron BlueSolar 75 15 MPPT Solar Regulator - Springers Solar
    Think handles 250w household. New can get the $300new or gumtree has plenty 2nd pnels for under $100 max.
    Allow $120 for some mc4 connects and a pre made lead from them for pv to mppt and 5m of 6mm lead to battery.
    Those prices made it cheaper for decent quality set up rather than saupacentre 12v folding panel setup.
    Dont have to be sunflower all day chasing the direct sunlight for panels to produce charge.
    To prove charge need 4.5v over charging voltage usually14. To 14.6 depending battery type. 19.0 volts basically. A 12v panell needs direct sunlight for voc of 19.0volts to start producing charge current.
    My panels is 44.0volt voc. So even in shade the voc is usually 19.0 voc. Watts maybe low but they can still pump charge in.
    Victron VE.Direct Bluetooth LE Dongle - Springers
    Dongle is about $75 atm. Need Bluetooth 4.0 to run the app.
    Very handy. 30day history is great feature of use and charging
    Will get a screen shot of app where it show mmpt suppling load terminals to frige 3.0amps and charging battery 2.0 amps at same time. Once had decent mppt you know why the cheaper Pwm solar chargers are so cheap. Because they are crap and kill batteries.
    4days of rain and storms leading up to xmas last year the Batterylife it cut power to load terminals on 4th day. But that was deliberate not using 2nd deep cycle battery to run fridge and thats at -15c. Battery that Batterylife function cut power was back to float charge on 5th day as was pure sunshine and my 165w panels peak draw was 195watts produced. Yes over rated amount as mppt must have really needed the power to charge up.
    gone
    1996 Discovery 1
    current
    Jul 2011
    Yarrawonga, Vic
    I have two domestic solar panels on the roof of my single axle van , with Viltron blue MPPT , keeps both batteries charged and fridge running even parked up through winter . And one domestic panel on the roof of Truck , ditto keeps house battery and fridge running permanently , then topples into the starter battery to keep that alive if parked up. A LOT cheaper and more efficient than so called Off road solar panels .
    May 2003
    On The Road
    why do you need a history of charge?
    surely your undry washing will tell you that yesterday was no good for your batts,,,
    I would think anyone that uses a monthly recording probably is set up so they can safely ignore it,,
    Logan Village area S.E. QLD
    Interesting Vlad.. Harry is rebuilding a classic caravan and it was suggested by Springers that we use a house solar panel as it will run the 12volt fridge more efficiently.
    Mrs hh
    Series Landy Rescue
    Our FB Page..
    Kallangur, Brisbane
    I have a VIctron MPPT 10/30 controller with two 200W, 24V (house?) panels on my van. The Victron Bluetooth interface has been useful in a geeky kind of way to see just how much energy is being harvested & to compare the voltage at the controller with that at the battery. A difference in voltage prompted me to uprate the cables between the controller & the batteries.
    When stopped, I use an Anderson plug to between the D4 & the caravan which keeps the Engel running & 2 Optima batteries + the cranking battery charged.
    Problem with the house panels is they measure roughly 1600x800mm & weigh 15 kilos each.
    + 2016 D4 TDV6
    Probably the same people who log mileage and fuel consumption Domestic solar panels for a vehicle
    Aside from knowing how far We can get on a tank, does it really help to know the history of $$$ consumed by the engine Domestic solar panels for a vehicle
    Bracken Ridge, Qld
    Quote Originally Posted by Milton477 View Post
    Is that for two panels or one?
    When I get the canopy on the ute I should have room for something 1600x800.
    gone
    1996 Discovery 1
    current
    St Helena,Melbourne
    4.28 MB
    Panels pop up on gumtree pretty cheap so if you have the space to mount them and a suitable reg then sounds like a good option.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Kallangur, Brisbane
    Quote Originally Posted by VladTepes View Post
    Each.
    + 2016 D4 TDV6
