Thread: Defender wheel fitment
    May 2009
    St Agnes, SA
    Has anyone fitted late model Defender wheels to a late 80's/early 90's RRC?
    Would be interesting to know if there were other options.
    Thanks in advance.
    '15 Discovery 4 HSE- The family bus and the kids like it!
    '89 RRC- My favorite of the bunch!
    Ex '03 Commodore 'S' ute- 450hp of uncracked 5.7lt and 6 speed manual uteness - Still crying that its gone
    Ex '06 GLXR Triton- *Gone and forgotten*
    Dec 2014
    FNQ
    AFAIK they are the same 16x7 ET33 as late RRC
    Are you looking for a different wheel, or a Defender wheel, or a different size/offset to standard?
    Roads?.. Where we're going, we don't need roads...
    MY92 RRC 3.9 Ardennes Green
    MY93 RRC LSE 300tdi/R380/LT230 British Racing Green
    MY99 D2 V8 Kinversand
    May 2009
    St Agnes, SA
    I was actually wondering if the Sawtooth design would fit.
    I see that there are a lot more options for a defender, but no mention of them fitting a RRC or Disco 1.
    I currently have the -25 offset steel rims and were wondering if the defender rims would fit over the standard hub on my 89 RRC.
    May 2017
    Quote Originally Posted by Konradical View Post
    Bearmach do a Sawtooth design for the RRC in a couple of different sizes.
    May 2009
    St Agnes, SA
    I have seen them.
    They don't list many specs about the wheel. Off set, hub clearance, hub diameter.
    I did find the Kahn design wheels and all their Defender wheels have a 114.5mm hub diameter. They also do a 20" wheel, which would be out of control.
    My biggest concern is the hub size. The current wheels are an updated 16x8 dynamic wheel, which I understand has the centres for the defender and I have fitted concentric rings so they sit properly on the hub.
    Can't remember what size I measured them at to have the rings made.
    I currently have a set of hurricanes on my POS and they don't sit on the hub centre. The studs have the right markings for alloy rims.
    Standard Rostyles didn't sit on the hub centre either.
    I'm not saying the rims you have don't need to.
    DL
    If you do a bit of a search there is a really good explanation of clamping force with studs and wheel nuts by Dougal from NZ, sadly no longer on this forum.
    DL
