Thread: Priming the oil galleries on a new engine.
    Irymple, Victoria, Australia
    I have just fitted a Holden motor that I rebuilt a while back for my series 3 shorty.
    As I don't like starting a motor up with all the oil galleys dry this is what I use to prime the system.
    A one litre hand weed sprayer with a length of 10mm rubber fuel line attached to it.
    On the other end I just fitted a 1/4 NPT hose tail and screwed it into the port where the oil pressure gauge
    normally fits. I had only put enough oil in the motor to bring the level up to the bottom mark
    on the dipstick to allow for the extra oil I was going to add when I primed the system. I pumped just over
    1.5 litres through the system to allow enough for the capacity of the oil filter, the oil pump, and all the galleys
    and hydraulic lifters. Once the system is primed I remove the hose barb from the block, refit the oil pressure
    sender, then turned the key, and barely two seconds later the oil light went out.
    Once the engine has had a run for a few minutes I then turn it off, let it sit for a bit, dip the oil, then add more
    if necessary, to bring it up to the top mark on the dipstick.
    Hopefully this might be helpful to others fitting a new engine.
    Cheers, Mick.
    1974 S3 88 Holden 186.
    1971 S2A 88
    1972 S3 88 x 2
    1959 S2 88 ARN 111-014
    1959 S2 88 ARN 111-556
    REMLR 88
    1969 BSA Bantam B175
    Mar 2007
    Warwick Qld
    Our old trick was to disconnect the coil lead, and wind the motor over until you get oil pressure, plug in the lead, and away you go
    1999 Disco TD5 ("Bluey")
    1996 Disco 300 TDi ("Slo-Mo")
    Avoca Beach
    AND in an RV8, before no dizzy models, you make up a tool to turn the dizzy and oil pump drive and run with an electric drill. The tool is just a long rod with the appropriate end ground onto it to fit the slot on later engines.
    When I did this first I thought what the hell was I doing with the Vaseline all these years.LOL
    Regards Philip A
    Feb 2017
    Deception Bay, Qld
    Quote Originally Posted by donh54 View Post
    I would pull the spark plugs to save the starter getting hot, make sure the plug leads can't create a spark incase she floods.
    Quote Originally Posted by whitey56 View Post
    Hence one of the reasons I use the pump.
    Cheers, Mick.
    1971 S2A 88
    1972 S3 88 x 2
    REMLR 88
