So the codes showed you have a EGR issue??  If not I would suspect the Discos MAP sensor issue when towing - basically when under load like towing MAP is not what the ECU expects and throws up a temporary fault display but clears by turning off - so if not EGR codes present try cleaning the MAP sensor - easily done.
If you shop around EGRs are not all that expensive but getting them blanked with a emulator/remap is preferred.
