Results 1 to 2 of 2
Thread: ford Ranger diesel Woes
    Gosnells
    Shrt story, #3 son, the newly minted Motor Mechanic bought a 2nd hand Ranger - Private sale - 3 litre (?) / 4cyl common-rail diesel. Went well, Useful amount of torque etc.
    Sadly the viscous fan failed (unlocked) , going uphill...and ..... Blew it's overflow bottle and lots of black-tainted Green Stuff everywhere. Waited to cool, then drove downhill & home. Quietly.!
    Checked everything including the stupid oil-cooler-in-block's-water-jacket. Cracked head around #3 & #4. Deemed 'UN-fixable' so his Mate-Of-A-Mate sourced a brand-new Chinese head, complete with valves fitted. At Mates-Rates obviously, being in the 'trade'...
    Installed and run for a week... but....
    Oil light flickering, running tooo warm and now it's WATER in the oil. - Catch-can says so...
    Head removed, sent off to another 'Head' shop and it is a banana... Several $$$$$s later, and new gasket/bolts/swearing and it's back on.
    Trial run and.... oil light flickering and running warm(er)
    Son has increased his vocabulary, and is totally 'over' the car. But between himself and late-night mates, has improved their Cyl-head R/R times !!!
    Question: - It is the opinion of this (ex) Range Rover owner / Father of Master Mechanic, that the unstable oil pressure lamp, coupled with running warm... indicates a cracked or otherwise damaged BLOCK.
    - What are my chances of being correct ?
    - Lower half of engine was left in the vehicle and by virtue of being cast iron, was assumed to be ok. No Visible-to-the-naked-eye cracks etc noted. 'Crack Dye Test' not done.
    Edit:- To the best of my knowledge, no straight-edge was run over the block... I know, 'cos it is still in my shed in exactly the same spot where I left it.
    My original suggestion of buying a 'good' 2nd-hand engine.... went nowhere.
    St Helena,Melbourne
    4.28 MB
    Block could be warped, really need to pull it out and strip it to find out for sure.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
