Ok so here's a question, and I wouldn't be surprised if the answer is "You're joking, right?!"
Anyway I am going to be putting some drawers in the back of the 130 and before I do so I want to tidy up the tray floor etc as much as possible.
There's a lot of dirt in there particulary where the corrugated floor meets front of the tub (i.e. cab end).
Any tips for getting all that dirt/grime out?
Then I'd like to try to ensure that
1. As much as possible, water is sealed from entry from underneath (or at least preventing rapid entry);
2. If water does get in there is a way for it to drain out.
And should I consider painting the inside of the tub with some sort of protectant paint goop?
Certainly can;t afford (and don't really need) that fancy protective tray liner stuff.
Other 1309 owners done anything along these lines?
gone
1993 Defender 110 ute "Doris"
1996 Discovery 1
current
 Master
						Master
						'95 Defender 130 Single Cab
HS2.8 TGV Powered
98% of all Land Rovers built are still on the road.
The other 2% made it home.
Cost difference between Britpart and Genuine seals: £2.04. Knowing that your brakes won't fail at any moment: Priceless.
No I haven't got a high pressure washer.
(The car wash thing doesn't seem adequate)
Renting them isn't as cheap as I'd hope, and buying one is only cheap if a bottom of the range one is bought )and why bother with a rubbish thing).
gone
1996 Discovery 1
current
Have you considered a rubber floor mat, the ine in my Falcon ute does a pretty good job of sealing the holes and providing a flat surface rather than the corrugated floor of the tray.
Tote
No I don't really need a floor mat (or the cost of one) on account of I'll have a big drawer set in there anyway.
Thanks for the suggestion though Tote, I'll keep it in mind.
gone
1996 Discovery 1
current
Come and borrow my Gerni.
gone
1996 Discovery 1
current
 Fossicker
						Fossicker
						I'm about to go through the same process, I'm planning on spraying it with carbuilders bully liner. I think it seems pretty reasonable at about $170 for 9 sqm coverage. I like that it is non toxic and should do a good job sealing everything up!
Never heard of that? Do you need a special gun for it or just a normal paint gun?
edit: I presume you mean this? Underbody stone guard, upol raptor, bully liner, lizardskin spray gun
with Bully Rubber Liner is one tough paint coating! Even better it's non-toxic and water based
gone
1996 Discovery 1
current
