I've seen one other that this has happened to.
Over torqued with rattle gun maybe??
Have you had brake rotors replaced or are they the originals?
A week ago I enjoyed a wonderful weekend out exploring some of the beautiful tracks around Newnes and managed to give Monty a pretty good seeing-to getting up 'The Steps' along with two other Defenders. All great fun and once back on the black top the following day, all seemed in good order.
Fast forward to last Friday afternoon, on the way home from a trip to see Daniel in Mortdale for a new Pop-Top seal and some electrical trickery. Approaching Richmond, I started to hear a grinding noise coming from the front axle. It didn't matter if I was in gear, accelerating, turning a corner or coasting in neutral; the noise was particular to the rotation of the axle i.e. when i slowed down, so did the noise.
I figured I must have caught a wee stone in the brake but then it got worse. I nursed Monty home for the next 5kms and then took the wheel off to have a look at what it was.
I'm not entirely sure HOW this happened.....but happen it did.
From the look of the colour of the steel, this was done a while ago so I assume it was the weekend in Newnes. Thank goodness the bolt had lodged itself and hadn't dropped back inside there on the motorway....that could have been very nasty indeed.
So, poor Monty had to go on a flat bed. I HATE it when that happens. It's pretty rare, thankfully, but to add a significant shake of salt to the wound, my Postie bike rear tyre valve decided to let go that afternoon and my girlfriend's car decided to leave it's throttle cable on Military Road.
A bad weekend for motoring and a good one for the NRMA.
UGH
I'll provide more detail once the boys at Ayres open it up and have a look. Not the first time they've seen this happen though, which is somewhat concerning.
Bobby
Roger
Just had a chat with Richard at Ayres.
He's seen this 4 or 5 times before which is why at Ayres they always replace these bolts when they do the brakes....but he said they're not sure why it does occasionally happen. Over-torqued perhaps? I know I've been giving Monty a good hiding off-road of late so I'm not surprised that something 'gave' but I wouldn't have guessed a brake bolt would be the first to go.
New disc going on but as I only had new discs put on a year ago, he's doing the repair free of charge. What a nice chap.
Bobby
Rotors did appear to be fairly new - no 'lip' developed on outer edge yet.
Nice of Richard to do "the repair free of charge".
I hope he torques all to the bolts to the specified 73Nm and you don't have a repeat experience.
Roger
Sorry to hear you had a bad string of luck with your vehicles. Interesting to hear that this isn't an uncommon thing if the mechanic was a bit enthusiastic with torqueing things up. Will keep it in mind.
Yeah you certainly gave the step a good go! Glad that Monty will be back on his feet soon
Thanks mate - picking him up this afternoon.
See you Saturday/ Sunday hopefully!
Bobby
