In hot weather you can run it to assist the fridge, otherwise just turn off with selection switch on central console (at least I canon mine 2012 SD/SE
Is it possible to totally turn off the rear aircon in a 7 seater???
I have nothing but a fridge and false floor and I just want it totally OFF.
I'd remove it all, if I could (can I??)
I'm guessing there might be a fuse somewhere for the rear system, so I might go looking for that, but any advice greatly appreciated.
2012 L320 Range Rover Sport Fuji White
REMLR 012
No 5 Trailer ARN 177-295
2006 Disco 3, 4L V6 Petrol SE Deceased Feb 26 2023
SOLD Engineers Trailer - no id
SOLD RAAF 231194 Perentie 110 GS - SIR ANGUS
SOLD 4MP COY Series 3 FFR 30-209
The rear button at the front panel - auto, on, off (no lights)...
And I wouldn’t remove it for quids! There’s only 2 in our vehicle but the rear AC helps the cabin hold temp easier and makes the fridges life easier too..
REMLR 012
Wrong button![]()
RTFM :-S
Got it "sorted", and yes, I did RTFM!
Not cold air coming from front driver side vent, leading me to think air con was going off. I now know there is cold air coming out of the passenger side.
series of coincidences about when I was turning the rear off, and where I was checking the temp at the front.
Now suspect there is a blend motor problem.
iiD tool check tomorrow to see what it tells me.
REMLR 012
