Thread: Towing Wiring Loom
    Nov 2015
    Black Rock
    Towing Wiring Loom
    Is it necessary to fit an OEM towing wiring loom to set up a P38 for towing? IIRC the P38 was the first Landrover that needed the towing loom to talk to the BECM. But I'm sure I've seen one wired up for towing using the old "connect the wires to the lights" trick.
    FYI, I have introduced a young family friend to the joys of P38 ownership (although I purchased a P38 in NZ from her Granny a few years ago, so she certainly knows a bit about them).
    The car came without a towing kit and she needs one.
    2013 D4 expedition equipped
    1966 Army workshop trailer
    When I fitted my towbar, I just wired it to the existing wiring as per RAVE. Too bad you're not closer, I have my towbar in the Markets.
    Nov 2015
    Black Rock
    Thanks Ron,
    I'll be back in Sydney later this year. I'll pass your ad on to the owner.
    Jan 2012
    Bendigo
    The plug with the indicators, brake park light etc is behind the drivers side rear panel.
    A reverse feed, and 10A fused feed is on the passenger side.
    Feb 2013
    Gosford, NSW, Australia
    In my MY96 there is a plug on each side with the main one being on the drivers side and the left side has reversing light connections
    Steve
