Results 1 to 10 of 12
Thread: Spreadsheet guru needed
    Jan 2011
    Gippsland
    I am not skilled at writing formulas and would welcome some help. What i want to be able do is enter a number into say C5 and have that number populated to say 20 other scattered cells in the matrix i will create..
    Can it be done ??
    LROCV member #131
    1999 build D2 TD5 Auto, Mantec snorkel, 2" LRA spring lift, ARB on board air, Ashcroft ATB, CMM air ram CDL shifter, swag & gold pans ....
    May 2017
    Quote Originally Posted by onebob View Post
    Can it be done ??
    I think a simple "=C5" in the destination cells should do the trick.
    Jan 2011
    Gippsland
    Sadly no.....Spreadsheet guru neededsays that formula cannot reference.
    LROCV member #131
    Aug 2016
    Try =+C5. Although =C5 works for me.
    2016.5 TDV6 Graphite D4,Corris Grey,APT sliders,Goe air comp plate,UHF & HF radio,Airflow snorkel,Discrete Winch,Compo rims with 265/65/18 Wildpeak AT3W, LLAMs,Traxide dual battery,EAS emergency kit,Mitch Hitch EGR blank & delete,ECU remap
    It should work (I just tested it). Did you leave out the quotes? Is C5 in the same spreadsheet?
    Jan 2011
    Gippsland
    Yup, left out the quotes. Shoulda said up front that i'm not using excel but Apple Numbers. I have used excel formula's before as a guide to successfully build a lottery checker in Numbers. So if =C5 works in excel then i need to tinker a bit more i guess...
    LROCV member #131
    Jan 2011
    Gippsland
    It's got something to do with setting the cell reference ie sum or product or the like.... I just tried product but no joy Spreadsheet guru needed
    LROCV member #131
    Bob are you willing to send me your sheet?
    Demo sheet works...
    Bob this sheet works....
    just a hack to test linking etc.. Download it and change extension from .xlsx to .numbers as this forum wont allow a numbers file format.
    Attached Files Attached Files
    Jan 2011
    Gippsland
    Thanks a million Tombie, i have downloaded it and will have look sometime today Spreadsheet guru needed
    LROCV member #131
